Problem deploying Package
I have a problem to deploy "ghost script" package.
I tested both in VM n physical machine both having the same problem.
Ghost script wont install. I tested deploy other app e.g JRE, adobe reader, office, SEP on the same machine it was working flawlessly
I checked back on the client system and i found a strange issue.
VM - package folder created and there's only 16kb files inside
Physical - package folder created and there's 6MB inside
Both doesnt contain the setupgs.exe file which is the installer.
Can i know which log can i check to troubleshoot the issue
Both VM n physical is deployed by same package but strange enough that VM only contain 16KB where physical content 6MB files
By the way,
I'm able to run the installation in silent thru the shared folder of the SCCM.
I jus redo the entire ghost script package and it is still the same
Some Update:
Files inside SCCM Shared folder there's 2 folder and 2 txt file and 2 exe file
Files inside physical package folder is 2 folder and 4 tmp file.
