802.1x problem during OSD (Machine Certificate Request Problem)
I am currently deploying machines over 802.1x network and am using user authentication to achieve this, however I found one problem.
The computer being deployed does not retrieve machine certificate until sometime after the OSD has finished. I have created a vbscript that creates an inf file (putting the hostname into the inf file). Then I use certreq to create the request, submit and accept cert from the enterprise CA.
This is all done in my win7 deployment task sequence while in current OS (not Winpe).
I have tested this on a computer that has been deployed and it works fine.
However during the OSD I get this error:
Error title: Certificate Request Processor
"The requested resource is in use. 0x800700aa (WIN32/HTTP: 170)
machine.inf([NewRequest] Subject ( "CN=testcomputer.mydomain.com")"
If I skip this step I am always needed to run a fix after each OSD where I change the authentication mode from user to Machine (802.1x).
Any idea on what could be wrong?
How are others doing this?
GauiC
