lexus-r6
Help me to deploy Win7, it's a simple question.
I have a question to deploy Win7 in SCCM 2007 R2.
My deployement is normally and automatically but not in the selection time zone.
The time zone windows appear and it must click to validate.
Therefore is not an automatic deployement.
Thanks you for yours answers.
Lexus
Ps : I'm french, so if you would like to answer me in french, it would be great.
Are you using an "Unattend.xml" file as part of the OS task sequence? If so, check the time zone settings within there to make sure they're set correctly. You might also check the BIOS settings to see what they're reading...
