Automatically Clients Aprove not working.
I have SCCM 2007 R3 in Mixed Mode and we automatically approve computers in trusted domains.
Every computer which is imaged from our network are approved, no problems there.
But when a computers is installed with a Stand-alone media from USB-Key the client will show up in the configuration manager console, but it will not be approved.
I need to manual click on approve.
In the Task Sequence i have the step: Setup windows and ConfigMgr, and this step will install the SCCM client.
But with the Stand-Alone Media the computer will be installed offline, so it can't communicate with the SCCM Server while installing.
What shall i do to resolve this problem?
Do we need to install the client manual after the computer is connected to our network and in our domain?
Thanks in advanced.
With kind regards,
Mitchel
I would change the Automatic Approval setting to Automatically approve all, in many scenarios it really doesn't matter if you approve all computers or if you only approve the ones in a trusted domain.
Regards,
Jörgen
Hi Jorgen,
Thanks for you reply, it's working now !
With kind regards,
Mitchel
