USMT creates folder with System and Hidden Permissions
I use SCCM 2007 and USMT4 to manage our Windows 7 SP1 x64 machines. The build is changing to a single partition (C:\) instead of a C and D drive. When a current machine is rebuilt I have been asked to move all files/folders (with some exceptions) to a new folder on the C drive called C:\Migrated_Data.
I can successfully exclude folders from both the C and D partitions and move the data to the C:\Migrated_Data folder. However, the Migrated_Data folder is created with System and Hidden permissions set. Unless these permissions are removed (attrib -s -h) the folder would not be visible to users.
I would like to understand why USMT is doing this but after a few days of searching I cannot find an answer to this problem. I could run the attrib -s -h c:\Migrated_Data command within an OSD task sequence step but I would prefer to stop USMT creating the root folder with these permissions.
All subsequent folders are not set to hidden.
I use the standard MigApp.xml and MigDocs.xml (which I have customised ---- see below) and a custom XML file to migrate application data for the CAD packages we use. I have tried recreating the config.xml (scanstate.exe /genconfig:config.xml) but that has made no difference.
Any help / pointers you could provide would be greatly appreciated.
<?xml version="1.0" encoding="UTF-8"?>
-<migration urlid="http://www.microsoft.com/migration/1.0/migxmlext/migdocs">
<!-- This component migrates data in system context -->
-<component context="System" type="Documents">
<displayName>MigDocSystem</displayName>
-<role role="Data">
-<rules>
<!-- GenerateDocPatterns takes 3 arguments 1. generate patterns for scattered files inside %ProgramFiles% 2. generate include patterns (FALSE generates exclude patterns) 3. generate patterns for system drive only -->
-<exclude filter="MigXmlHelper.IgnoreIrrelevantLinks()">
-<objectSet>
<script>MigXmlHelper.GenerateDocPatterns ("FALSE","FALSE","FALSE")</script>
</objectSet>
</exclude>
<!-- Example: <exclude> <objectSet> <pattern type="File">%CSIDL_COMMON_VIDEO%\* [*]</pattern> </objectSet> </exclude> -->
-<contentModify script="MigXmlHelper.MergeShellLibraries('TRUE','TRUE')">
-<objectSet>
<pattern type="File">* [*.library-ms]</pattern>
</objectSet>
</contentModify>
-<merge script="MigXmlHelper.SourcePriority()">
-<objectSet>
</objectSet>
</merge>
-<include>
-<objectSet>
<script>MigXmlHelper.GenerateDocPatterns('false','true','false')</script>
</objectSet>
</include>
-<unconditionalExclude>
-<objectSet>
<pattern type="File">D:\EVARCHIVE\* [*]</pattern>
<pattern type="File">C:\EVARCHIVE\* [*]</pattern>
<pattern type="File">C:\DrvInst\* [*]</pattern>
<pattern type="File">D:\_SMSTaskSequence\* [*]</pattern>
<pattern type="File">C:\_SMSTaskSequence\* [*]</pattern>
<pattern type="File">C:\Oracle\* [*]</pattern>
<pattern type="File">C:\ThinInst\* [*]</pattern>
<pattern type="File">C:\Intel\* [*]</pattern>
<pattern type="File">C:\PerfLogs\* [*]</pattern>
<pattern type="File">C:\Support\* [*]</pattern>
<pattern type="File">C:\SWTOOLS\* [*]</pattern>
</objectSet>
</unconditionalExclude>
</rules>
</role>
</component>
<!-- This component migrates data in user context -->
-<component context="User" type="Documents">
<displayName>MigDocUser</displayName>
-<role role="Data">
-<rules>
-<objectSet>
</objectSet>
</exclude>
<!-- Example: <exclude> <objectSet> <pattern type="File">%CSIDL_MYVIDEO%\* [*]</pattern> </objectSet> </exclude> -->
-<objectSet>
</objectSet>
</contentModify>
-<objectSet>
</objectSet>
</merge>
-<include>
-<objectSet>
<pattern type="File">D:\* [*]</pattern>
</objectSet>
</include>
-<locationModify script="MigXmlHelper.Move('C:\Migrated_Data')">
-<objectSet>
</objectSet>
</locationModify>
-<objectSet>
</objectSet>
</rules>
</role>
</component>
</migration>
  • 2 months later...
