P3nnyw1se
Need help reading my client.msi log
My OSD is atm. stopping when its time to put on the client.
and as a result aborts and skips the entire Applications part.
looking at the log I see several things I would think needs to be fixed, but I simply don't know enough about it.
Could someone help me out decode stuff?
I believe the problem comes here.
Property(S): PrimaryVolumePath = C:
MSI (s) (C0:C8) [13:03:55:978]: Note: 1: 1729
MSI (s) (C0:C8) [13:03:55:978]: Transforming table Error.
MSI (s) (C0:C8) [13:03:55:978]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (C0:C8) [13:03:55:978]: Produkt: Configuration Manager Client -- Konfigurationen mislykkedes. = Product: Configuration Manager Client -- Configuration Failed
MSI (s) (C0:C8) [13:03:55:978]: Windows Installer har konfigureret produktet igen. Produktnavn: Configuration Manager Client. Produktversion: = Windows installer has configured the product again
5.00.7804.1000. Produktsprog: 1030. Producent: Microsoft Corporation. Produktet blev konfigureret igen eller fejlstatus: 1603.
MSI (s) (C0:C8) [13:03:55:978]: Attempting to delete file C:\WINDOWS\Installer\24f2f.mst
MSI (s) (C0:C8) [13:03:55:978]: Unable to delete the file. LastError = 32
MSI (s) (C0:C8) [13:03:55:978]: Deferring clean up of packages/files, if any exist
MSI (s) (C0:C8) [13:03:55:978]: MainEngineThread is returning 1603
MSI (s) (C0:C8) [13:03:55:993]: RESTART MANAGER: Session closed.
MSI (s) (C0:C8) [13:03:55:993]: No System Restore sequence number for this installation.
=== Logføring stoppet: 12-11-2013 13:03:55 ===
I suppose the issue is primary volume path then? to C:\ ?
I use "OSDPreservedDisk = False" and
set Logical Drive to c:\ ..
I use this to install windows to c:\
Instead of the standard D:\
This used to work using the standard install.wim from the windows CD
Now I captured my own image which was also installed to d:\ on a virtual machine.
NOTE: If I set the OSDPreservedDisk = TRUE
It doesn't error, and installs fully.. but to D:\
