In my Unattend.xml (attached) I specified to skip any OOBE, yet I am still prompted with the Windows 10 "Let's Get Connected" screen during OSD? Is there something I can pass directly in the task sequence to avoid this page? I have previously used the Apply Network Settings task sequence step, however, this didn't work with the variety of computer systems. Using "Join Domain or Workgroup" works perfectly, but it only works after the Setup Windows and Config Manager step.
	Any suggestions?
Unattend.xml
