SCCM 2012 R2 - Class B public IP range
Hi Guys,
I am designing an SCCM solution for a client and have run into a possible issue. The SCCM server is going to be sitting in a "private" address range with routing to a public class B address range. The servers to be managed are in the public range and are domain joined.
Will the agents believe they are on the internet or will everything work as normal?
Hopefully this has a simple solution/answer :)
Thanks Guys,
Sean
I was hoping it would be this simple. I will fire up a test environment next week and check it out.
Thanks for the advice will report back
