takeown problem
Hi
I have Windows 10 v1511 Enterprise 64 bit with two Microsoft account.
From the Command Prompt (run as administrator), I tried to write
takeown /S localhost /U "<Microsoft_account_(E-Mail_Address)>" /P <User_password>" /F "<Directory_path>" /R /A /D Y
but I get the "Access Denied" error. Why?
Bye
does it work if you specify a normal user account (and not a microsoft email account)
If I write the net user command, the profile names of the Microsoft accounts are displayed.
If, however, I write
takeown /S localhost /U "<Account_profile_name>" /P "<Password>" /F "<Directory_path>" /R /A /D Y
Windows indicates that this user does not exist.
Also, if I try to activate the hidden administrator
net user Administrator /Active:yes
net user Administrator "<Password>"
and then I try to write
takeown /S localhost /U Administrator /P "<Password>" /F "<Directory_path>" /R /A /D Y
Windows always indicates that this user does not exist.
So, how should I use the /U option of takeown?
Bye
  • 2 weeks later...
I think I found the best solution to remove a directory structure which also contains symbolic links and with ACLs managed by TrustedInstaller or Authenticated Users or System users:
takeown /F "<Directory_path>" /A /R /D Y /SKIPSL >nul 2>&1
icacls "<Directory_path>" /reset
icacls "<Directory_path>" /grant:r Administrators:(OI)(CI)F /inheritance:e /Q /C /T /L >nul 2>&1
pushd "<Directory_path>" && ( rd /S /Q "<Directory_path>" 2>nul & popd )
Bye
Since the /d option value of the takeown varies according to the language of Windows, how do I make sure that this command works properly for each language?
Bye
