Remote tools simultaneous connectivity
hello!
i have sccm 2007
1. what restrictions are imposed on the organization of remote sessions to a workstation?
2. The maximum number of remote connections through the console sccm 2007 a group of employees (number)?
3. Does the simultaneous connectivity to a single workstation in several sessions by different employees, the program will behave thus?
  1. None
  2. Technical none but the Provide might have issue with over 100 connections to the Provider.
  3. There are windows restriction not CM07 restriction for this. Generally only 1 connection to a workstations.
