Build and Capture Win 7 Pro
Hi All,
New here and new to SCCM 2012 R2.
I have a question.. so i've setup SCCM 2012 R2, all working ok so far that i can tell.
I am using PXE to boot, it loads up fine, enter pswd, select the Build and capture task, that runs but even though I've select no product key, it stops during process and asks for key i choose, skip it continues all ok, captures the image but then it comes up asking for product key and for me to create a user account and name PC - how do i stop this? i was expecting it to just load to windows desktop?
I think i've missed a step somewhere but not sure where...
Thanks all
Kev
No, I am using the 180 day eval version downloaded from technet and told it to not enter a key.
Kev
I will see is MS have one as a 180 eval.
Kevin
hmm doesn't appear to be on technet anymore from what i can tell.... :( dam....
These images are in a test environment so I can get some practical experience with using SCCM and creating a image etc as if I would in real world.
I figured i'd create a win 7 image in a VM and then use that to then be pushed out to my laptop, adding the drivers etc as required in the TS etc but first stage is the build a capture although i'm wondering whether to just build it directly in VM as i would do normally and then just capture it, whats best practice in industry for this or is it either way? personal choice?
Shame i got to enter product key, was hoping eval would just run for 180 days...
Kev
Thanks - will try that when it cools down here - just too hot to have my Vms running atm....
Kev
