SCCM 2012 Distribution Point issue
Hello Guys,
We have a SCCM setup as a primary server & 50 DP's at branches but clients are not getting EP or any updates from respective branch DP , rather it comes directly to Site server, please help.
How do you have your site boundary groups laid out?
We have each boundary group assigned to a subnet, then the local DP is assigned to that boundary group. This causes the clients to be pointed to their local DP.
We have boundaries defined with the IP addresses range & Clients of particular Boundary group is assigned with DP of their IP address range only.still clients searches for updates & gets updates directly from site server.This causes the heavy bandwidth utilization, please help.
Either your boundaries are not configured correctly, or the content isn't available on the local site server and fallback has been enabled on your other server, hence it going across the wan
