+++ MSI application not discovered [MSI Product Code: {A38F51ED-D01A-4CE4-91EB-B824A00A8BDF}, MSI Product version: ] AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
App enforcement environment:
Context: Machine
Command line: msiexec /i "Setup X64.msi" /q
Allow user interaction: No
UI mode: 0
User token: null
Session Id: 4294967295
Content path: C:\Windows\ccmcache\2
Working directory: AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
Prepared working directory: C:\Windows\ccmcache\2 AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
Found executable file msiexec with complete path C:\Windows\system32\msiexec.exe AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
Prepared command line: "C:\Windows\system32\msiexec.exe" /i "Setup X64.msi" /q /qn AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
Valid MSI Package path = C:\Windows\ccmcache\2\Setup X64.msi AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
Advertising MSI package [C:\Windows\ccmcache\2\Setup X64.msi] to the system. AppEnforce 1/13/2017 11:51:08 PM 1564 (0x061C)
Executing Command line: "C:\Windows\system32\msiexec.exe" /i "Setup X64.msi" /q /qn with system context AppEnforce 1/13/2017 11:51:11 PM 1564 (0x061C)
Working directory C:\Windows\ccmcache\2 AppEnforce 1/13/2017 11:51:11 PM 1564 (0x061C)
Post install behavior is BasedOnExitCode AppEnforce 1/13/2017 11:51:11 PM 1564 (0x061C)
Waiting for process 3428 to finish. Timeout = 120 minutes. AppEnforce 1/13/2017 11:51:11 PM 1564 (0x061C)
Process 3428 terminated with exitcode: 1602 AppEnforce 1/13/2017 11:51:15 PM 1564 (0x061C)
Looking for exit code 1602 in exit codes table... AppEnforce 1/13/2017 11:51:15 PM 1564 (0x061C)
Unmatched exit code (1602) is considered an execution failure. AppEnforce 1/13/2017 11:51:15 PM 1564 (0x061C)
++++++ App enforcement completed (6 seconds) for App DT "Trend Micro Worry-Free Business Security Agent - Windows Installer (*.msi file)" [ScopeId_9F6D74A7-7A6E-4215-AF8B-92796D5BB9B2/DeploymentType_eff89a9c-d26b-4d71-af9d-ef34f24c41c5], Revision: 1, User SID: ] ++++++ AppEnforce 1/13/2017 11:51:15 PM 1564 (0x061C)
