PXE boot almost working - HELP!
Just a quick message to say that I have finally got this working.
Thank you for your advice.
I now have another issue, although I suspect this is easier to resolve.
The task sequence bombs out with the following error:
It is not supported to deploy an x86 architecture OS from a amd64 boot image ApplyOperatingSystem 1/14/2010 11:03:59 AM 1432 (0x0598)
Managed to resolve this one (I am moving quickly now :)) by changing the boot media to x86.
Now I am getting the error:
BOOTMGR IS MISSING
PRESS CTRL&ALT&DEL
Any advice?
  • 4 weeks later...
How did you resolve the problem? I am receiving these errors? HELP :)
WARNING: _SMSTSSiteSigningCertificate Not Set. This might cause client failures in native mode. smspxe 2/9/2010 2:57:44 PM 6560 (0x19A0)
WARNING: _SMSTSRootCACerts Not Set. This might cause client failures in native mode. smspxe 2/9/2010 2:57:44 PM 6560 (0x19A0)
WARNING: _SMSTSCertStoreName Not Set. This might cause client failures in native mode. smspxe 2/9/2010 2:57:44 PM 6560 (0x19A0)
WARNING: _SMSTSCertSelection Not Set. This might cause client failures in native mode. smspxe 2/9/2010 2:57:44 PM 6560 (0x19A0)
These are not errors, but just warnings. They could cause failures, if you are running in Native Mode.
Besides this do you get other errors or notification?
