jka816
Clients won't update after WSUS rebuild
I've been at this for a couple weeks and haven't had any lucky resolving it myself. I'm around ready to give up and rebuild or primary site.
SCCM Ver: CB1802
Our old WSUS server was 2012R2 running WID and we wanted to move it to 2016 and SQL. I removed the SUP role, removed the server from SCCM, then decomed the server. I rebuilt the WSUS server on 2016, connected to SQL DB, installed SUP role, and synced WSUS. In SCCM everything appears to be functioning normally, I can see updates, metadata, create software update groups, deploy, etc and Offline Servicing works but Clients and Build and Capture task sequences fail to update. This issue is not specific to one client, update, or OS version. It's everything. I've included logs from a Windows 10 1703 client I just imaged.
Following may help when looking through logs:
SUG UID: {FB172790-25B5-4030-94EF-084AF60311D4}
Unique Update ID: 2018-05 Update for Windows 10 Version 1703 for x64-based Systems (KB4132649)    5/17/2018 12:00:00 PM    f176e292-745f-4757-9b64-c25f1d382bb0
Clients can see the SUGs deployed to them but they still fail to update:
EnumerateUpdates for action (UpdateActionInstall) - Total actionable updates = 0
I do see some interesting behavior in the WindowsUpdateLog:
2018/05/29 09:40:33.8562624 4204  4372  Misc            [0]106C.1114::05/29/2018-09:40:33.856 [endpointproviders]EP: error: 0x8024500C : - failed to get SLS data
2018/05/29 09:40:33.8562631 4204  4372  Misc            [0]106C.1114::05/29/2018-09:40:33.856 [endpointproviders]EP: error: 0x8024500C: GetSecondaryServicesEnabledState failed
2018/05/29 09:40:33.8562643 4204  4372  Agent           [0]106C.1114::05/29/2018-09:40:33.856 [agent]AutoRecovery: DetectAndToggleServiceState failed 0x8024500c
2018/05/29 09:40:33.8562714 4204  4372  Agent           [0]106C.1114::05/29/2018-09:40:33.856 [agent]Failed to resolve federated serviceId 9482F4B4-E343-43B6-B170-9A65BC822C77, hr=8024500c
2018/05/29 09:40:33.8569169 4204  4372  Agent           [0]106C.1114::05/29/2018-09:40:33.856 [agent]Failed to execute service registration call {0212BB3F-3F60-41E9-A2F8-134D35857144}, hr=8024500c (cV: Y9kDJUwh+kyup8zk.1.0.1)
2018/05/29 09:40:33.8586463 4204  4372  IdleTimer       [0]106C.1114::05/29/2018-09:40:33.858 [agent]WU operation (SR.Device Driver Retrieval Client ID 1, operation # 3) stopped; does<NULL> use network; is not at background priority<NULL>
2018/05/29 09:40:33.8597622 4204  4368  DownloadManager [0]106C.1110::05/29/2018-09:40:33.859 [agent]Received power state change notification: Old: <unknown>; New: AC.
2018/05/29 09:40:33.8597634 4204  4368  DownloadManager [0]106C.1110::05/29/2018-09:40:33.859 [agent]Power state changed from <unknown> to AC.
2018/05/29 09:40:33.8647205 356   1832  ComApi          [0]0164.0728::05/29/2018-09:40:33.864 [comapi]* END *   Federated Search failed to process service registration, hr=0x8024500C (cV = Y9kDJUwh+kyup8zk.1.0)
2018/05/29 09:40:33.8670209 356   1756  ComApi          [0]0164.06DC::05/29/2018-09:40:33.867 [comapi]ISusInternal:: DisconnectCall failed, hr=8024000C
I also see the following behavior in the ScanAgent.Log, but I'm not sure if it's normal or not:
CScanAgent::ScanByUpdates - Found UpdateClassification cd5ffd1e-e932-4e3a-bf74-18bf0b1bbd83 for Update:bba02b7f-1d17-4e92-bae9-9f3651dcc2de	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
CScanAgent::CanPerformOnlineCatScan - Cannot perform online category scan as update does not belong to pre-defined classifications for this.	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
Found CategoryID of :a3c2375d-0c8a-42f9-bce0-28333e198407 for Update:c03178c9-b5d2-4c5f-819f-c8871513e23d	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
CScanAgent::ScanByUpdates - Found UpdateClassification 0fa1201d-4330-4fa8-8ae9-b877473b6441 for Update:c03178c9-b5d2-4c5f-819f-c8871513e23d	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
Found CategoryID of :a3c2375d-0c8a-42f9-bce0-28333e198407 for Update:c68e52ad-4e74-4f15-95d2-17da18f296fe	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
CScanAgent::ScanByUpdates - Found UpdateClassification 0fa1201d-4330-4fa8-8ae9-b877473b6441 for Update:c68e52ad-4e74-4f15-95d2-17da18f296fe	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
Found CategoryID of :d2085b71-5f1f-43a9-880d-ed159016d5c6 for Update:cbb9515d-b809-4d11-983b-6047fea6c907	ScanAgent	5/29/2018 9:46:30 AM	11232 (0x2BE0)
Any help or ideas of where to look would be much appreciated.
