SCCM 2007 R3 Upgrade Issues
I have been trying to install R3, which requires hotfix 977384 but get failures on all my servers EXCEPT the first one I did, the CSS.
All servers are on 2007 SP2, with the clients also upgraded. All are 2003 Server with SQL2005.
I have seem variations which suggest language is wrong, however all servers are using the same language version of SCCM (English)
Anyone else having these sort of issues?
Thanks! Ron
The msi log is pasted below:
=== Logging started: 11/9/2010 20:29:20 ===
Action start 20:29:20: INSTALL.
Action start 20:29:20: SmsReadSetupRegValues.
[20:29:20] Start SmsReadSetupRegValues
[20:29:20] Get Site Server Setup information from Software\Microsoft\SMS\Setup
[20:29:20] The registry value of 'Installation Directory' is 'E:\Microsoft Configuration Manager'.
[20:29:20] The registry value of 'Full Version' is '4.00.6487.2000'.
[20:29:20] The registry value of 'Version' is '6487'.
[20:29:20] The registry value of 'Type' is '1'.
[20:29:20] The registry value of 'Server' is 'FRMESCCM01'.
[20:29:20] The registry value of 'Database Name' is 'SMS_DUB'.
[20:29:20] The registry value of 'UI Installation Directory' is 'E:\Microsoft Configuration Manager\AdminUI'.
[20:29:20] The registry value of 'Full UI Version' is '4.00.6487.2000'.
[20:29:20] The registry value of 'UI Version' is '6487'.
[20:29:20] The registry value of 'LanguageID' is '00000409'.
[20:29:20] The registry value of 'Language' is 'English:00000409'.
[20:29:20] The registry value of 'Root Directory' is 'E:\Microsoft Configuration Manager'.
Action ended 20:29:20: SmsReadSetupRegValues. Return value 1.
Action start 20:29:20: LaunchConditions.
Action ended 20:29:20: LaunchConditions. Return value 0.
Action start 20:29:20: FindRelatedProducts.
Action ended 20:29:20: FindRelatedProducts. Return value 0.
Action start 20:29:20: AppSearch.
Action ended 20:29:20: AppSearch. Return value 0.
Action start 20:29:20: CCPSearch.
Action ended 20:29:20: CCPSearch. Return value 0.
Action start 20:29:20: RMCCPSearch.
Action ended 20:29:20: RMCCPSearch. Return value 0.
Action start 20:29:20: ValidateProductID.
Action ended 20:29:20: ValidateProductID. Return value 1.
Action start 20:29:20: CostInitialize.
Action ended 20:29:20: CostInitialize. Return value 1.
Action start 20:29:20: FileCost.
Action ended 20:29:20: FileCost. Return value 1.
Action start 20:29:20: IsolateComponents.
Action ended 20:29:20: IsolateComponents. Return value 0.
Action start 20:29:20: CostFinalize.
Action ended 20:29:20: CostFinalize. Return value 1.
Action start 20:29:20: SetODBCFolders.
Action ended 20:29:20: SetODBCFolders. Return value 0.
Action start 20:29:20: MigrateFeatureStates.
Action ended 20:29:20: MigrateFeatureStates. Return value 0.
Action start 20:29:20: SmsPatchDisableNonVersionComp.
[20:29:20] Start SmsPatchDisableNonVersionComp
[20:29:20] Checking the non versioned file [managementclassdescriptions.xml], the date is [1265035200]
[20:29:20] Checking the non versioned file [osd_tasksequencemediawizard.xml], the date is [1265035200]
[20:29:20] Checking the non versioned file [sccm2007ac-sp2-kb977384-x86-enu.msp], the date is [1265035200]
[20:29:20] Checking the non versioned file [tsspropertieslist.xml], the date is [1265035200]
[20:29:20] Exit SmsPatchDisableNonVersionComp
Action ended 20:29:20: SmsPatchDisableNonVersionComp. Return value 1.
Action start 20:29:20: SmsPatchStopService.
[20:29:20] Start SmsPatchStopService
[20:29:20] Start SmsPatchPrepareAffectedServiceList
[20:29:20] Check status for SMS_SITE_COMPONENT_MANAGER
[20:29:20] Need stop SMS_SITE_COMPONENT_MANAGER
[20:29:20] SmsProdPatchGetDependentServices for SMS_SITE_COMPONENT_MANAGER
[20:29:20] Add Service SMS_SITE_COMPONENT_MANAGER
[20:29:20] Check status for SMS_EXECUTIVE
[20:29:20] Need stop SMS_EXECUTIVE
[20:29:20] SmsProdPatchGetDependentServices for SMS_EXECUTIVE
[20:29:20] Add Service SMS_EXECUTIVE
[20:29:20] Check status for SMS_SITE_SQL_BACKUP
[20:29:20] Need stop SMS_SITE_SQL_BACKUP
[20:29:20] SmsProdPatchGetDependentServices for SMS_SITE_SQL_BACKUP
[20:29:20] Add Service SMS_SITE_SQL_BACKUP
[20:29:20] Check status for SMS_SITE_VSS_WRITER
[20:29:20] Need stop SMS_SITE_VSS_WRITER
[20:29:20] SmsProdPatchGetDependentServices for SMS_SITE_VSS_WRITER
[20:29:20] Add Service SMS_SITE_VSS_WRITER
[20:29:20] Check status for SharedAccess
[20:29:20] Service [sharedAccess] isn't started, skip it
[20:29:20] Check status for ccmexec
[20:29:20] Need stop ccmexec
[20:29:20] SmsProdPatchGetDependentServices for ccmexec
[20:29:20] Add Service ccmexec
[20:29:20] Check status for iphlpsvc
[20:29:20] Service [iphlpsvc] isn't existing, skip it
[20:29:20] Check status for wscsvc
[20:29:20] Service [wscsvc] isn't existing, skip it
[20:29:20] Check status for Winmgmt
[20:29:20] Need stop Winmgmt
[20:29:20] SmsProdPatchGetDependentServices for Winmgmt
[20:29:20] Found dependent service: tmlisten
[20:29:20] Found dependent service: CcmExec
[20:29:20] Check status for tmlisten
[20:29:20] Need stop tmlisten
[20:29:20] Add Dependent Service tmlisten
[20:29:20] Add Service Winmgmt
[20:29:20] Reset Service List: SMS_SITE_COMPONENT_MANAGER
SMS_EXECUTIVE
SMS_SITE_SQL_BACKUP
SMS_SITE_VSS_WRITER
ccmexec
tmlisten
Winmgmt
[20:29:20] Exit SmsPatchPrepareAffectedServiceList
[20:29:20] Stop Service SMS_SITE_COMPONENT_MANAGER
[20:29:21] SMS_SITE_COMPONENT_MANAGER status is stopped
[20:29:21] Stop Service SMS_EXECUTIVE
[20:29:49] SMS_EXECUTIVE status is stopped
[20:29:49] Stop Service SMS_SITE_SQL_BACKUP
[20:29:51] SMS_SITE_SQL_BACKUP status is stopped
[20:29:51] Stop Service SMS_SITE_VSS_WRITER
[20:29:52] SMS_SITE_VSS_WRITER status is stopped
[20:29:52] Stop Service ccmexec
[20:29:54] ccmexec status is stopped
[20:29:54] Stop Service tmlisten
[20:34:54] Start tmlisten timer out, status is 4
[20:34:54] Starting (rollback) ccmexec
[20:34:55] ccmexec status is 4
[20:34:55] ccmexec is STARTED
[20:34:55] Starting (rollback) SMS_SITE_VSS_WRITER
[20:34:55] SMS_SITE_VSS_WRITER status is 4
[20:34:55] SMS_SITE_VSS_WRITER is STARTED
[20:34:55] Starting (rollback) SMS_SITE_SQL_BACKUP
[20:34:55] SMS_SITE_SQL_BACKUP status is 4
[20:34:55] SMS_SITE_SQL_BACKUP is STARTED
[20:34:55] Starting (rollback) SMS_EXECUTIVE
[20:34:55] SMS_EXECUTIVE status is 4
[20:34:55] SMS_EXECUTIVE is STARTED
[20:34:55] Starting (rollback) SMS_SITE_COMPONENT_MANAGER
[20:34:56] SMS_SITE_COMPONENT_MANAGER status is 4
[20:34:56] SMS_SITE_COMPONENT_MANAGER is STARTED
[20:34:56] Exit SmsPatchStopService
Action ended 20:34:56: SmsPatchStopService. Return value 3.
Action ended 20:34:56: INSTALL. Return value 3.
Property(S): SmsIncorrectLang = This hotfix does not match the installed language version of Configuration Manager 2007
Property(S): SmsNotInstalled = No Configuration Manager 2007 site or administrator console was found on this computer
Property(S): SmsNotRunningInElevated = Please run the installer with "Elevated Privileges"
Property(S): SmsRunSQLScriptFail = The database upgrade script failed
Property(S): VersionNT = 502
Property(S): InstSMSInstallDir = E:\Microsoft Configuration Manager\
Property(S): TARGETDIR = E:\Microsoft Configuration Manager\
Property(S): InstSMSProviderDir = E:\Microsoft Configuration Manager\
Property(S): InstSMSUIInstallDir = E:\Microsoft Configuration Manager\
Property(S): ALLUSERS = 1
Property(S): ARPHELPLINK = http://support.microsoft.com/KB/'>http://support.microsoft.com/KB/[KBNumber]
Property(S): ARPNOMODIFY = 1
Property(S): ARPNOREPAIR = 1
Property(S): ARPURLINFOABOUT = http://support.microsoft.com
Property(S): BannerBitmap = bannrbmp
Property(S): ButtonText_Back = < &Back
Property(S): ButtonText_Browse = Br&owse
Property(S): ButtonText_Cancel = Cancel
Property(S): ButtonText_Exit = &Exit
Property(S): ButtonText_Finish = &Finish
Property(S): ButtonText_Ignore = &Ignore
Property(S): ButtonText_Install = &Install
Property(S): ButtonText_Next = &Next >
Property(S): ButtonText_No = &No
Property(S): ButtonText_OK = OK
Property(S): ButtonText_Remove = &Remove
Property(S): ButtonText_Repair = &Repair
Property(S): ButtonText_Reset = &Reset
Property(S): ButtonText_Resume = &Resume
Property(S): ButtonText_Retry = &Retry
Property(S): ButtonText_Return = &Return
Property(S): ButtonText_Yes = &Yes
Property(S): CompleteSetupIcon = completi
Property(S): CustomSetupIcon = custicon
Property(S): DefaultUIFont = DlgFont8
Property(S): DialogBitmap = dlgbmp
Property(S): DlgTitleFont = {&DlgFontBold8}
Property(S): ErrorDialog = ErrorDlg
Property(S): ExclamationIcon = exclamic
Property(S): IAgree = No
Property(S): InfoIcon = info
Property(S): InstallerIcon = insticon
Property(S): INSTALLLEVEL = 3
Property(S): InstallMode = Typical
Property(S): KBNumber = 977384
Property(S): Manufacturer = Microsoft Corporation
Property(S): MsiLogging = vociewarmup!
Property(S): PackageCode = {79B9CB28-FE39-44DE-B69E-19C0AF534CDB}
Property(S): PatchHasSQLScript = 0
Property(S): PatchPrimarySiteApplicable = 1
Property(S): PatchRemoteAdminUIApplicable = 1
Property(S): PatchRemoteProviderApplicable = 1
Property(S): PatchSecondarySiteApplicable = 1
Property(S): PatchSMSFullUIVersion = 4.00.6487.2000
Property(S): Publisher = Microsoft Corporation
Property(S): PatchSMSFullVersion = 4.00.6487.2000
Property(S): PatchSMSPackageLanguage = English:00000409
Property(S): PatchSMSProductTitle = Microsoft System Center Configuration Manager 2007
Property(S): PatchSMSUIVersion = 6487
Property(S): ProductCode = {AF9EC0A2-C680-4054-849B-D278F5FFD61B}
Property(S): ProductLanguage = 1033
Property(S): ProductName = Software Update for ConfigMgr 2007 SP2 (KB977384)
Property(S): Progress1 = Installing
Property(S): Progress2 = installs
Property(S): PROMPTROLLBACKCOST = P
Property(S): RemoveIcon = removico
Property(S): RepairIcon = repairic
Property(S): Setup = Setup
Property(S): ShowUserRegistrationDlg = 1
Property(S): SmsConnectDatabaseFail = Cannot connect to database server : [instSMSDatabaseServer], database name : [instSMSDatabaseName]
Property(S): SmsIncorrectRole = This hotfix does not match the installed role of Configuration Manager 2007
Property(S): SmsIncorrectVersion = This hotfix is not valid for this version of Configuration Manager 2007
Property(S): SMSProductShortTitle = ConfigMgr 2007
Property(S): UpdateCode = {74D2C02A-3DDC-45B7-8407-8B261E6217E1}
Property(S): UpgradeCode = {A99BADA9-9031-47C9-B57C-C436A2A18596}
Property(S): Wizard = Setup Wizard
Property(S): ProductVersion = 4.0.6487.2157
Property(S): PatchSMSVersion = 6487
Property(S): PublishingGroup = System Center Configuration Manager Sustained Engineering
Property(S): ReleaseType = Hotfix
Property(S): ServicePackNumber = 2
Property(S): PatchAdminUILanguage = 00000409
Property(S): InternalVersion = 1018
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 0
Property(S): ROOTDRIVE = E:\
Property(S): InstIsRemoteProvider = 0
Property(S): InstIsRemoteAdmin = 0
Property(S): InstIsSecondarySite = 0
Property(S): InstIsPrimarySite = 1
Property(S): InstSMSAdminUILanguage = 00000409
Property(S): InstSMSLanguage = English:00000409
Property(S): InstSMSDatabaseName = SMS_DUB
Property(S): InstSMSDatabaseServer = FRMESCCM01
Property(S): InstSMSFullUIVersion = 4.00.6487.2000
Property(S): InstSMSFullVersion = 4.00.6487.2000
Property(S): InstSMSUIVersion = 6487
Property(S): InstSMSVersion = 6487
Property(S): ResetServiceList = SMS_SITE_COMPONENT_MANAGER
SMS_EXECUTIVE
SMS_SITE_SQL_BACKUP
SMS_SITE_VSS_WRITER
ccmexec
tmlisten
Winmgmt
Property(S): ACTION = INSTALL
Property(S): UILevel = 3
Property(S): OriginalDatabase = E:\SMSAdmin.SP2\SCCM.R3\Hotfix\SCCM2007-SP2-KB977384-ENU.msi
Property(S): DATABASE = C:\WINDOWS\Installer\e3b6adc.msi
Property(S): COMPANYNAME = **
Property(S): USERNAME = ** User
Property(S): Privileged = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 5.2.3790.3959
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 11/9/2010
Property(S): Time = 20:34:56
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 19
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = FRMESCCM01
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-1101489508-55990008-2834211104-52707
Property(S): LogonUser = 3oy-is
Property(S): AdminUser = 1
Property(S): VirtualMemory = 4265
Property(S): PhysicalMemory = 3326
Property(S): Intel = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property(S): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(S): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Documents and Settings\3oy-is\My Documents\My Pictures\
Property(S): LocalAppDataFolder = C:\Documents and Settings\3oy-is\Local Settings\Application Data\
Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(S): SendToFolder = C:\Documents and Settings\3oy-is\SendTo\
Property(S): RecentFolder = C:\Documents and Settings\3oy-is\Recent\
Property(S): PrintHoodFolder = C:\Documents and Settings\3oy-is\PrintHood\
Property(S): PersonalFolder = C:\Documents and Settings\3oy-is\My Documents\
Property(S): NetHoodFolder = C:\Documents and Settings\3oy-is\NetHood\
Property(S): FavoritesFolder = C:\Documents and Settings\3oy-is\Favorites\
Property(S): AppDataFolder = C:\Documents and Settings\3oy-is\Application Data\
Property(S): CommonFilesFolder = C:\Program Files\Common Files\
Property(S): ProgramFilesFolder = C:\Program Files\
Property(S): TempFolder = C:\DOCUME~1\3oy-is\LOCALS~1\Temp\
Property(S): RemoteAdminTS = 1
Property(S): System16Folder = C:\WINDOWS\system\
Property(S): SystemFolder = C:\WINDOWS\system32\
Property(S): WindowsVolume = C:\
Property(S): MsiNTProductType = 3
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 2
Property(S): WindowsBuild = 3790
Property(S): VersionMsi = 3.01
Property(S): VersionDatabase = 110
Property(S): CLIENTPROCESSID = 2792
Property(S): CLIENTUILEVEL = 2
Property(S): CURRENTDIRECTORY = H:\
Property(S): PackagecodeChanging = 1
Property(S): ProductState = -1
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): BackupRoot = C:\WINDOWS\$NtUninstallKB977384$\
Property(S): TARGETDIR_adminui = E:\Microsoft Configuration Manager\adminui\
Property(S): TARGETDIR_adminui_bin = E:\Microsoft Configuration Manager\adminui\bin\
Property(S): TARGETDIR_bin = E:\Microsoft Configuration Manager\bin\
Property(S): TARGETDIR_bin_i386 = E:\Microsoft Configuration Manager\bin\i386\
Property(S): TARGETDIR_bin_i386_system32 = E:\Microsoft Configuration Manager\bin\i386\system32\
Property(S): TARGETDIR_bin_i386_system32_smsmsgs = E:\Microsoft Configuration Manager\bin\i386\system32\smsmsgs\
Property(S): TARGETDIR_adminui_xmlstorage = E:\Microsoft Configuration Manager\adminui\xmlstorage\
Property(S): TARGETDIR_adminui_xmlstorage_consoleroot = E:\Microsoft Configuration Manager\adminui\xmlstorage\consoleroot\
Property(S): TARGETDIR_adminui_xmlstorage_forms = E:\Microsoft Configuration Manager\adminui\xmlstorage\forms\
Property(S): ClientPatchID = {0856B5B5-C423-476E-BC4B-C8FE92223BEC}
Property(S): ClientPatchFile = sccm2007ac-sp2-kb977384-x86-enu.msp
Property(S): PatchHasClient = 1
Property(S): TARGETDIR_client = E:\Microsoft Configuration Manager\client\
Property(S): TARGETDIR_client_i386 = E:\Microsoft Configuration Manager\client\i386\
Property(S): TARGETDIR_client_i386_hotfix = E:\Microsoft Configuration Manager\client\i386\hotfix\
Property(S): TARGETDIR_client_i386_hotfix_KB977384 = E:\Microsoft Configuration Manager\client\i386\hotfix\KB977384\
Property(S): TARGETDIR_adminui_xmlstorage_other = E:\Microsoft Configuration Manager\adminui\xmlstorage\other\
Property(S): TARGETDIR_adminui_bin_i386 = E:\Microsoft Configuration Manager\adminui\bin\i386\
Property(S): TARGETDIR_adminui_bin_i386_00000409 = E:\Microsoft Configuration Manager\adminui\bin\i386\00000409\
Property(S): BackupRoot_00000409 = C:\WINDOWS\$NtUninstallKB977384$\00000409\
Property(S): ARPSYSTEMCOMPONENT = 1
MSI (s) (94:4C) [20:34:56:253]: Product: Software Update for ConfigMgr 2007 SP2 (KB977384) -- Installation operation failed.
=== Logging stopped: 11/9/2010 20:34:56 ===
The main issues seems to be here:
R3 requires SP2 & KB977384, can you confirm if both are installed prior to attempting to install R3 ? also is the sql db on these boxes or off ?
are you only getting errors when trying to install the hotfix (prior to installing R3 ?)
This error is when trying to install the Hotfix 977384. I can never get to the point of installing the actual R3.
Ron
That was it... Thanks so much... unbelievable that having trend on makes the patch say it's the wrong version of SCCM.
  • 7 months later...
Actually, Trend isn't causing it to say that it's the wrong version of SCCM. The "Property" table in the MSI database is simply defining those errors in case it needs to display them. Those "Property(S)" lines you pasted are simply references to the error text, not actually generating the errors themselves.
Hope this helps.
Cheers,
Trevor Sullivan
http://trevorsullivan.net
http://twitter.com/pcgeek86
