SRed
An application installs correctly with abnormal exit code, what to do?
Hi all,
I'm deploying PDF Creator in my environment and have noticed that the install completes successfully, but the program reports a strange exit code, namely -1073740940. I'm trying to specify this code in my advertisement/package, but I'm not sure where to do this. Because of the strange exit code, this package, though succesful, shows up as an error in my Advertisement logs.
You may want to consider wrapping the command in a batch file, or other script file, which you can directly instruct to exit with a return value of 0. In batch, you simply do:
exit 0
In VBscript, you do:
wscript.quit(0)
In PowerShell, you simply do:
exit 0
Hope this helps.
Cheers,
Trevor Sullivan
http://trevorsullivan.net
http://twitter.com/pcgeek86
