Content will not distribute
We've been testing Configuration Manager 2012 for a little while and ran into a problem. We've been using it to build a few systems and wanted to add a system type. We downloaded and added a driver pack like we'd done before but it won't distribute. The error we get is that it failed to access the source directory and lists one of the directories. The possible causes are that the DP doesn't have the rights to get to the folder or that it is out of disk space. We've checked both and there is plenty of drive space and the contents have the same security as everything else.
We've spent a few hours on it and aren't really sure where to go next. Can someone provide some assistance?
Thank you!
Is it on a remote DP or is it on the local sccm DP?
It is on the local SCCM DP.
I thought about that too. We can path to it fine on the server. The path isn't that bad: \\SCCMServer\Drivers\HP8300x64
The driver folders are a little longer but we've done the exact same thing with similar names 4 other times with no issues.
We found this in the distmgr.log file...
TakeContentSnapshot() failed. Error = 0x80040154 SMS_DISTRIBUTION_MANAGER 9/14/2012 11:10:48 AM 2924 (0x0B6C)
The source directory doesn't exist or the 'Configuration Manager' service cannot access it, Win32 last error = 340 SMS_DISTRIBUTION_MANAGER 9/14/2012 11:10:48 AM 2924 (0x0B6C)
It also seems like any new content we add right now gets the same error.
Edit:
We also setup another DP on the same LAN and all the old content will distribute just fine but nothing new will go.
Found the problem!!!
Remote Differential Compression was uninstalled by a domain policy. As soon as we re-installed it, it started working like a charm!
