Problems with capture part of task sequence
Hi All,
I am having a problem capturing a gold image in SCCM 2007. I have created a build and capture task sequence and the build part of the task sequence completes with no issues however it will not capture the system image after this.
Can you please advise what logs I should look at to troubleshoot this and what entry in the log indicates that the capture part of the task sequence has started thanks.
Note that I start the task sequence using PXE boot
Hi All Just a quick update I found that when I removed a capture condition the sysprep runs however the image still will not capture getting error below:
unknown host (gethostbyname failed) TSManager 17/10/2013 13:14:59 1980 (0x07BC)
hr, HRESULT=80072ee7 (e:\nts_sms_fre\sms\framework\osdmessaging\libsmsmessaging.cpp,7714) TSManager 17/10/2013 13:14:59 1980 (0x07BC)
sending with winhttp failed; 80072ee7 TSManager 17/10/2013 13:14:59 1980 (0x07BC)
Will retry in 45 second(s) TSManager 17/10/2013 13:14:59 1980 (0x07BC)
Retrying... TSManager 17/10/2013 13:15:44 1980 (0x07BC)
CLibSMSMessageWinHttpTransport::Send: URL: GLASCCM01.DW.LOCAL:80 CCM_POST /ccm_system/request TSManager 17/10/2013 13:15:44 1980 (0x07BC)
