Lordnicon79
JDK deploying. Need Help!!
how can i copy two .jar files into a local directory.
The Problem:
Standard User have read permission.
only admin have read write permission.
Maybe with a xcopy Batch file? but how did i have to configure the sccm. what did i have to do?
Iam a newbi in the sccm world and i hope to get help at this forum.
Thanks for all help
8 answers to this question
Hi ,
thanks for your helpful page, i tried the instructions and everything looked good.
But now i try to start a new Paket and from now on i will allways get a 0x1(1) error message.
Maybe i think i have a node in my head, i can't find the right way.
I use the following parameters:
I create a package
I check the box package has source files
I specify the folder where the files are: \\server\subfolder$\lib
I specify a standard program
next…
I name the program (copy) and specify in the command line:
filecopy.bat
(that looks like :
cmd.exe /c copy /y "%~dp0Files2Copy*.*" "%programfiles\Java\jdk1.8.0_45\jre\lib\security")
I run whether or not logged in with admin rights
I distribute the package, the deploy to the client.
in ccmcache i can see all the files (batch and the subfolder) = check!
But in the exexecmgr.log i see:
Execution is completet for program copy. the exit cod is 1, the execution status is FailureNonRetry.
Do you have any suggestion ?
I hope you can help me...
I saw that your location ist even Germany.
wir können auch in deutsch kommunizieren...
Ich habe die änderungen vorgenommen und die Batch datei noch mehr vereinfacht:
if not exist c:\test md c:\test
copy /y "%~dp0files2copy*.*" c:\test
Sorry, you got to keep in in english, so people can understand what you said. forum rules.
What about the "files2copy" part in your path ? Is that a folder name or do the files names all start with files2copy? If it is a older you are still missing a backslash "files2copy\*.*" Also make sure that the target directory exists on the machine.
ok :-)
the Files2Copy is a folder. Here are the two folders
Server: \\servername\subfolder$\Unlimited Security Policy JDK 8
(\\servername\subfolder$\Unlimited Security Policy JDK 8\security)
Client: C:\Program Files\Java\jdk1.8.0_45\jre\lib\security
Yesterday night, i tried to start by zero and build a test file:
Batch:
copy "%~dp0Files2Copyfile1.txt" c:\test
copy ".\Files2Copy\file2.txt c:\test
copy "%~dp0\Files2Copy\file3.txt" c:\test
copy "%~dp0\Files2Copy\file4.txt" "c:\test"
copy /y "%~dp0Files2Copyfile5.txt" c:\test
copy "%~dp0*.*" c:\test
Server folder :
(\\servername\subfolder$\Unlimited Security Policy JDK 8\test)
Client folder :
c:\test
It was ok! Only File3.txt, File4.txt and the last one worked fine!
OK now i know how to build the folder names. (I hope)
after that i tried it at my problem-batch-file but again "Failure".
now, after a short night, i will test ist again with this changed Version of my batch file:
batch:
copy "%~dp0\security\local_policy.jar" "C:\Program Files\Java\jdk1.8.0_45\jre\lib\security\"
copy "%~dp0security\US_export_policy.jar" "%ProgramFiles%\Java\jdk1.8.0_45\jre\lib\security"
copy "%~dp0\security\README.txt" "C:\Program Files\Java\jdk1.8.0_45\jre\lib\security"
Server Folder:
\\servername\subfolder$\Unlimited Security Policy JDK 8/
(\\servername\subfolder$\Unlimited Security Policy JDK 8/security)
Client Folder:
But now, i have two questions:
1. is it ok to use copy /y ....... ? or may i only use copy ..... (without /y )
2. must be the server folder and the clientfolder with the same name?
Like: \\servername\subfolder$\Unlimited Security Policy JDK 8/Securtiy
or is this ok?
//servername/subfolder$/Unlimited Security Policy JDK 8/
Thanks for you help !!!
Yessssss.... i fixed it!
But i don't know how! :-)
i compared both ways: 1. first batch(1) file with folders and the 2nd. batch (2)(Test)
i copied partly the batch (1) commands into the batch (2) an it worked good.
until everything was combined into the batch(2) and that is the right and woking one:
copy /y "%~dp0\Files2Copy\*.*" "C:\Program Files\Java\jdk1.8.0_45\jre\lib\security"
Server folders: \\server\subfolder$\Oracle\Development Kit\Unlim.Sec. Pol. JDK8
client folders: C:\Program Files\Java\jdk1.8.0_45\jre\lib\security
the only one thing i changed is the foldername of the last two server folder:
first: \\servername\subfolder$\Unlimited Security Policy JDK 8\test
now: \\servername\subfolder$\Unlim.Sec. Pol. JDK8\Folder2Copy
Maybe the foldername was to long ! ?!
Now it runs perfekt !
Thanks for your help ! Have a nice Weekend !!
