Devices Per OU With Friendly Name
I'm looking to get a report that will show me how many devices we have in each location. The best way to do this would be by using OU information.
I located the script on this page that will show me each OU but would like to modify it so that it so it shows a more descriptive name instead of the OU. Is this something easy to adjust?
select
    ou.ou,
    count(*) as 'total'
from
    (SELECT sys.ResourceID, max(OU.System_OU_Name0) AS 'OU' FROM dbo.v_R_System AS sys INNER JOIN dbo.v_RA_System_SystemOUName AS ou ON sys.ResourceID = ou.ResourceID GROUP BY sys.ResourceID) ou
group by
    ou.ou
Order by
    ou.ou
Instead of showing 'domain\usa\california\sacramento\desktops' to be able to show 'Sacramento Desktops'.
So how exactly would you determine that that OU is called Sacramento Desktops?
It sound like a manual process to me. As such you can use a monster "Case" statement to convert each OU into a better description.
I checked into the case statements and was able to figure it out.
Thanks for your help.
select
    ou.ou,
    count(*) as 'total'
from
    (SELECT sys.ResourceID, case
when max(OU.System_OU_Name0) like 'domain/usa/california/sacramento/desktop%' THEN 'Sacramento Desktops'
when max(OU.System_OU_Name0) like 'domain/usa/california/sacramento/laptop%' THEN 'Sacramento Laptops'
ELSE max(OU.System_OU_Name0) END
group by
    ou.ou
Order by
    ou.ou
