shamos
Help me anyweb
i try to add Add 32 bit and 64 bit boot.wim files i got this error
Error: Data Source Information
Source location: \\Sccm\sms_c01\OSD\boot\i386\boot.wim
Boot Image: 1 - Microsoft Windows Vista PE (x86)
Error: Package Information
Name: x86 windows pe boot enviroment for sccm
Error: Errors
The specified file can not be imported. Please make sure the file is not read only and you have read and write access to it.
and when i tried to update distrbiution point for x86 boot image got this error
Error: Boot image to update:
Microsoft Windows Vista PE (X86)
Error: Actions to perform:
Add ConfigMgr binaries
Disable Windows PE command line support
Add drivers
Error: Failed to import the following drivers:
Error: The wizard detected the following problems when updating the boot image.
The ConfigMgr Provider reported an error.: ConfigMgr Error Object:
instance of SMS_ExtendedStatus
Description = "Failed to insert OSD binaries into the WIM file";
ErrorCode = 2152205056;
File = "e:\\nts_sms_fre\\sms\\siteserver\\sdk_provider\\smsprov\\sspbootimagepackage.cpp";
Line = 3824;
ObjectInfo = "CSspBootImagePackage::PreRefreshPkgSrcHook";
Operation = "ExecMethod";
ParameterInfo = "SMS_BootImagePackage.PackageID=\"C0100001\"";
ProviderName = "WinMgmt";
StatusCode = 2147749889;
i have done all steps before this step, so please need your help.
i use windows server 2008 and sccm 2007 sp1
9 answers to this question
try logging on to that server with an account that has local administrative permissions on the server
see here ...
Error: Errors
is there relation with Pxe filter ? i talk about this vbs.
another this when am trying to update distrbuition point for boot image (x86)
i got this error
Enable Windows PE command line support
Add drivers
Line = 3824;
no it has nothing to do with the PXE filter for MDT, can you please check your System Status component logs in SCCM to see if there are any obvious problems, other than that are you creating the boot images as outlined in the Deploy Vista guide here ?
