reza
problem in installing client agent
hi first i have to say thanks a lot about this really good web site and your help.
install sccm 2007 compeletly and all of the computers in active directory come to my console , after that i wanted to install agent on them for example on the sccm server , nothing did happend, i was waiting for ccmsetup.exe task in the task manager but it didnt appeare . so i check the event viewer and i found these errors in application part:
1-first error :
On 8/3/2009 12:03:50 PM, component SMS_MP_CONTROL_MANAGER on computer PARSIANSCCM reported: MP Control Manager detected DMP is not responding to HTTP requests. The http status code and text is 401, Unauthorized.
2- second error :
The kerberos client received a KRB_AP_ERR_MODIFIED error from the server P2038-5$. The target name used was RPCSS/P2038-2.Parsian.com. This indicates that the password used to encrypt the kerberos service ticket is different than that on the target server. Commonly, this is due to identically named machine accounts in the target realm (PARSIAN.COM), and the client realm. Please contact your system administrator.
3-thirth error :
DCOM was unable to communicate with the computer P2013-31 using any of the configured protocols.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
4-forth error :
A provider, BcdProv, has been registered in the WMI namespace, root\wmi, but did not specify the HostingModel property. This provider will be run using the LocalSystem account. This account is privileged and the provider may cause a security violation if it does not correctly impersonate user requests. Ensure that provider has been reviewed for security behavior and update the HostingModel property of the provider registration to an account with the least privileges possible for the required functionality.
5-fifth error :
A provider, PolicyAgentInstanceProvider, has been registered in the WMI namespace, root\ccm\Policy\Machine, to use the LocalSystem account. This account is privileged and the provider may cause a security violation if it does not correctly impersonate user requests.
i dont know which one is really related to my problem . please help me about this problem as soon as you can , this is really important for me , if you need any information please tell me to send you as soon as possible.
about my situation i have to say , my SCCM server is windows 2003 r2 with SQL server SP2 and all of the prerequisitise was OK , and my clients are windows 2000 SP4 , when i want to install client on them there is nothing happend , ccmsetup.exe dont appear in task manager even on sccm server , i want to install client with push installation method. thanks for your help.
4 answers to this question
you have to fix this error first
  Quote
sounds to me like you have an authorisation problem, so.... did you configure IIS exactly as specified in the SCCM setup guides here ? including all the WEBDAV parts ?
thanks for your answer, i will try to solve the problem that you said , but are you sure is it the problem? and yes i intalled IIS with webdav compeletly and the webdav is allow . about the error can you help me how to solve it?
