Use SCCM without system management container
I believe if you cannot use the System Management container, you have to publish MPs to DNS instead (this will allow clients to find management points to communicate with). https://technet.microsoft.com/en-gb/library/bb632936.aspx < this is for CM07 but I assume it will be the same for CM12.
AFAIK the System Management container is used exclusively for SCCM, you just need the site server full control on all descendent objects on that container for it to publish the MP details to AD.
When i want to install the cmmsetup with this command on my testclient: ccmsetup.exe /mp:sccm.mydomain.local SMSMP=ccm.mydomain.local
There will be this result. I just do not find the error. That makes me crazy for hours.
Is the MP listed in the log file the correct one? If it is then you need to re-check your CM12 client package and ensure that all the setting are correct.
