BzowK Posted February 23, 2015 Report post Posted February 23, 2015 Hey Guys / Niall - OSD task sequences have been one of the many things under my umbrella since starting my current position about 8 months ago. As with any environment, issues come and go - however - there's been one which occurs randomly and cannot easily be reproduced which I cannot figure out. Our current OSD task sequence is fairly detailed and supports all models we use. Depending on choices made from a frontend created via AutoIT, it can do many things including apply Win7 OS, provision Win 8 OS, install apps, etc. The steps which install the applications are straightforward and consists of a mix of Applications and Packages which reboots in between where required. The Issue The issue is that on some builds (1-2 per week), the TS will stop and throw an error due to an application which failed to install. The exit code is always 16389 and the application affected is random. We can continue the TS but must manually install whichever application threw it after the TS finishes. When imaging systems, we can do 1 - 12 at a time which are all running the same TS on the same computer model, but only one have the issue. In the past when trying to run the TS on the same system again, it works without the issue. In the past 3 weeks, it's occurred when installing CCleaner and Cisco AnyConnect client - both Applications - but in the past has affected many different ones. I unfortunately don't have log files to attach at the moment, but will soon. I wanted to go ahead and post in case this rang a bell for anyone who may have a suggestion or have heard of it before. Any ideas? Thanks Guys! Quote Share this post Link to post Share on other sites More sharing options...
Ariendg Posted February 26, 2015 Report post Posted February 26, 2015 Same strange random problems with installing applications In OSD/Task Sequence with ConfigMgr R2 2012 (Cu3) here also. The task sequence failed to install application <APP> for action <ACTION> in the group () with exit code 16389. The operating system reported error 2147500037: Unspecified error The task sequence manager could not successfully complete execution of the task sequence. A failure exit code of 16389 was returned. No appenforce.log created! smsts.log errors: NotifyProgress received: 24 (Application download failed ) Execution status received: 24 (Application download failed ) App install failed. Install application action failed: '<APP>'. Error Code 0x80004005 Especially with applications you should also consult other log files like App*.log DCMAgent.log CIAgent.log CIDownloader.log Policy*.log How about the errors in these logfiles (same timeframe)? I have got it working after disabling the 2015 January updates group. It could be that some December patches are included in this group. Now troubleshooting with the individual updates. Strange situation in our environment is we only have the random problems on our site location. Deploying to Virtual Machines in Datacenter no application errors at all. Quote Share this post Link to post Share on other sites More sharing options...
core Posted February 26, 2015 Report post Posted February 26, 2015 I've noticed this as well. Seems to be a bug within the task sequence process. I removed the applications from the T/S and created packages for those applications. Haven't had a problem yet. Quote Share this post Link to post Share on other sites More sharing options...
Ariendg Posted February 26, 2015 Report post Posted February 26, 2015 I've noticed this as well. Seems to be a bug within the task sequence process. I removed the applications from the T/S and created packages for those applications. Haven't had a problem yet. Exit Code 16389 is a code you only will see at application deployment. Changing back to packages will be our last resolution because of a few advantages. Why is using application deployment after OSD no problem I cannot understand. In my opinion it is not that different. Provisioning mode true and ServiceUI But back to topic please. Quote Share this post Link to post Share on other sites More sharing options...
Ludo01170 Posted May 24, 2017 Report post Posted May 24, 2017 Hello guys, I know that the post is old but, did you find any solution about it ? I encounter exactly the same problem ... and I want to understand what happens. Thanks a lot Quote Share this post Link to post Share on other sites More sharing options...
d1774393@urhen.com Posted November 25, 2019 Report post Posted November 25, 2019 Hello, old topic, but I thing I found the issue. The task sequence execution engine starts the next installation before the current one is finished. The engine waits for an exit code from msiexec and starts the next installation right away, but in some cases msiexec is still doing stuff. You get this error in the TS status messages, but the actual application exit code received is 1618. That was it in my case at least. Hope this helps 1 Quote Share this post Link to post Share on other sites More sharing options...
Stephan Posted November 29, 2021 Report post Posted November 29, 2021 This Topic is really old now, but the failure seems to be consistent over the years. I also get randomly 16389 errors during the OSD TS. @d1774393@urhen.com: Did you find a solution for that other than creating packages ? Quote Share this post Link to post Share on other sites More sharing options...
leedswigs Posted April 21, 2023 Report post Posted April 21, 2023 i have the same problem, however mine is happening on Packages or Applications The task sequence manager could not successfully complete execution of the task sequence. A failure exit code of 16389 was returned. The operating system reported error 53: The network path was not found "The task sequence manager could not successfully complete execution of the task sequence. A failure exit code of 16389 was returned" is consistent "The operating system reported error 53: The network path was not found" this can be a different error i have 2 failures out of 20 using the same task sequence, one is on MS Office and one which is just a cmd line to add a user to local admin group, so nothing fancy going on Quote Share this post Link to post Share on other sites More sharing options...
khluz Posted January 8 Report post Posted January 8 Hi all Meanwhile it's 2026 and we also have this issue on any task sequence on any application to install randomly. SCCM Version Current Branch 2503. Not the newest, but not old. Sometimes we can solve the problem by delete the application from the task sequence and add it again. Sometimes it helps to update the distribution point with the failed application. Random. Does anybody have a real solution or an official statemant from microsoft? tx to any help sincerly CL Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted January 18 Report post Posted January 18 based on what a previous guy said " Quote The task sequence execution engine starts the next installation before the current one is finished. The engine waits for an exit code from msiexec and starts the next installation right away, but in some cases msiexec is still doing stuff." I guess you could create a powershell script to check for msiexec process doing this and if so 'wait' until it's done, before installing the app, have you tried that ? here's some untested code that you could use as a wrapper for each app, maybe it will help [CmdletBinding()] param( [int]$TimeoutSeconds = 0, # 0 = wait indefinitely [int]$PollIntervalSeconds = 3, # how often to poll [switch]$Quiet # suppress non-verbose status messages ) function Write-Info { param([string]$Message) if (-not $Quiet) { Write-Host $Message } } function Test-MsiInProgressRegistry { # Windows Installer sets this key while an MSI is actively installing $keyPath = 'HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\InProgress' try { if (Test-Path $keyPath) { # Some builds create the key with values; treat existence as "busy" $item = Get-Item $keyPath -ErrorAction SilentlyContinue $props = $null try { $props = Get-ItemProperty $keyPath -ErrorAction SilentlyContinue } catch {} return $true } } catch {} return $false } function Get-MsiexecProcesses { # Fetch msiexec.exe along with command lines (CIM needed for CommandLine) try { return Get-CimInstance Win32_Process -Filter "Name='msiexec.exe'" -ErrorAction SilentlyContinue } catch { # Fallback to Get-Process (no command line available) try { return (Get-Process -Name msiexec -ErrorAction SilentlyContinue | ForEach-Object { [pscustomobject]@{ ProcessId = $_.Id Name = $_.ProcessName CommandLine = $null } }) } catch { return @() } } } function Test-MsiexecDoingWork { # Heuristic: if command line indicates an actual MSI operation (install/repair/uninstall/update) param( [Parameter(Mandatory)] $Proc ) $cl = $Proc.CommandLine if ([string]::IsNullOrWhiteSpace($cl)) { # If we lack command line, be conservative: any msiexec process could be active return $true } # Common operation switches for msiexec: # /i, /x, /f*, /update, /uninstall, /package, /qn, /qb, /passive often accompany installs $patterns = @( '\s/([ix])\b', # /i install, /x uninstall '\s/f[a-z]*\b', # /f, /fa, /fu, etc. (repair) '\s/update\b', # patch/update '\s/uninstall\b', '\s/package\b', '\.msi(\s|$)', # explicit MSI file '\.msp(\s|$)' # patch file ) foreach ($p in $patterns) { if ($cl -match $p) { return $true } } # Sometimes msiexec runs as the service side without clear switches; if in doubt, treat as busy return $true } function Test-MsiBusy { # Returns $true if Windows Installer is likely busy $procs = @(Get-MsiexecProcesses) if ($procs.Count -gt 0) { foreach ($p in $procs) { if (Test-MsiexecDoingWork -Proc $p) { return $true } } } if (Test-MsiInProgressRegistry) { return $true } return $false } # ---------------------------- # Main wait loop # ---------------------------- $start = Get-Date if ($TimeoutSeconds -gt 0) { Write-Info "Waiting for Windows Installer (msiexec) to finish (timeout: $TimeoutSeconds s, poll: $PollIntervalSeconds s)..." } else { Write-Info "Waiting for Windows Installer (msiexec) to finish (no timeout, poll: $PollIntervalSeconds s)..." } # If already idle, return immediately if (-not (Test-MsiBusy)) { Write-Info "Windows Installer appears idle." return } # Otherwise, poll until idle or timeout while (Test-MsiBusy) { if ($TimeoutSeconds -gt 0) { $elapsed = (New-TimeSpan -Start $start -End (Get-Date)).TotalSeconds if ($elapsed -ge $TimeoutSeconds) { Write-Warning "Timed out waiting for Windows Installer after $([int]$elapsed) seconds." exit 1 } if (-not $Quiet) { $remaining = [math]::Max([int]($TimeoutSeconds - $elapsed), 0) Write-Host ("MSI busy... ({0}s remaining). Next check in {1}s." -f $remaining, $PollIntervalSeconds) } } else { if (-not $Quiet) { Write-Host "MSI busy... next check in $PollIntervalSeconds s." } } Start-Sleep -Seconds $PollIntervalSeconds } Write-Info "Windows Installer is now idle." Quote Share this post Link to post Share on other sites More sharing options...
