Simassochelp
SCCM 1706 running on Server 2016 - software update point has old products
Hi
I have installed SCCM  1706 on Windows Server 2016 with SQL 2016 running on the same box.
When adding and configuring the Software Update Point i have noticed that  the 'Products' list has nothing listed post 2010 i.e no Windows 10/Server 2012/2016.
I noticed the following prerequisite for Windows 10 servicing:
Before you enable the Upgrades classification, you must install WSUS hotfix 3095113 on all software update points in your hierarchy.
If you do not install this update, the Windows 10 Servicing feature will not properly function. See http://support.microsoft.com/kb/3095113 for more information.
Only Windows Server 2012 and later versions running WSUS support the Upgrade classification of updates.
Additionally, to service Windows 10 Version 1607 and later, you must install and configure KB3159706 using the guidance at https://support.microsoft.com/en-us/kb/3159706.
WSUS hotfix 3095113 is for Server 2012 and will not install on Server 2016
Any help would be greatly appreciated!
Rgds,
Simassochelp
Edited by Simassochelp
