Jeff May-Stahl
HELP!!! Unable to upgrade through Task Sequence
so it could be that CU ( 10586.1478 ) that is causing problems, you can always uninstall it on one machine, and do an upgrade as a test
I have found other posts with the same issue but no resolutions. It seems that the Feb and March CUs broke something, preventing upgrade to 1709. Upgrading to 1703 seems to be working. On my systems, removing the latest CU fails. I'm not sure if they are unable to be removed in general or if it is just my environment.
