Imaging over USB issue
Hi all
Usually image over PXE but have a need to image over USB but over USB am facing an issue 0x80070057 -  the parameter is incorrect. I have looked as the SMSTS log and attached some screen shots from there and the task sequence - i have a feeling its when finding the drive to apply the OS but not certain - what is it im missing here?
Thanks!
sccmerror1.thumb.PNG.c7892117b1d92b5b4e237c4640ecbc74.PNGsccmerror2.thumb.PNG.bc7f81b6bce0bd9ada42c1339e3bb528.PNGsccmerror3.PNG.945143bf412843b7da2ce949d5d12c25.PNG
Attached the log and the steps of partition - strangely this only seems to happen when imaging over USB
smsts.log
<![LOG[The action (Partition Disk 0 - UEFI) has been skipped because the condition is evaluated to be false]LOG]!><time="14:50:41.848+480" date="11-02-2018" component="TSManager" context="" type="1" thread="1420" file="instruction.cxx:688">
so check your options on that step.
specifically this,..,
Expand a string: _SMSTSMediaType]LOG]!><time="14:50:41.848+480" date="11-02-2018" component="TSManager" context="" type="0" thread="1420" file="utility.cpp:805">
<![LOG[Expand a string: OEMMedia]
