Deploying SCCM 2007 client using SUP?
go into your Site settings, Component Configuration, Software Update Point, what is it set to there ?
also why use this method to deploy the client ?
have your researched the following links ?
Configuring Configuration Manager Client Deployment
How to Configure the Configuration Manager Client Push Installation Account
Specifies how to configure the account used during Client Push if you are using this method of client deployment.
How to Configure Request Ports for the Configuration Manager Client
Specifies how to configure the ports used by clients to communicate with the site.
How to Provision Configuration Manager Client Installation Properties using Group Policy
Specifies how to provision client computers with installation properties using Windows Group Policy.
How to Prevent the Configuration Manager Client Software from Being Installed on Specific Computers
Specifies how to prevent the Configuration Manager 2007 client being installed on computers you identify that should not have the client software installed.
How to Configure the Configuration Manager Computer Client Agent
Specifies how to configure general settings for all client computers in your Configuration Manager 2007 site.
I think I have hit all of those pages along the way except for the one about configuring ports. As for configuring the SCCM client install policies via Group policy, I didn't think that was necessary since we already extended the AD schema. I thought since that was done, we didn't need to use a the template, but I haven't seen where else I could specify the installation settings.
What other methods would you advise for deploying the client? I tried client push, but could only get it to work by disabling the firewall on client machines, which is not an option for us. That is why we are attempting to use the SUP method, which I think we are close to getting working, except for I made some port changes and the WSUS component completely stopped working last night, so I am reinstalling that now, using the default website, which I think may have been an issue initially, because I chose custom and then had the incorrect ports. Hoping this sorts it out, but we'll see.
As a side note, it is beyond ridiculous that client push won't work without taking the firewall down on clients.
  • Replies 29
  • Views 21.5k
  • Created
  • Last Reply
Top Posters In This Topic
you do raise some interesting points, and i'm interested to see where you get with this
however, for me client push *manually via wizard or site wide* would be my preferred way,
you do realise you don't have to take the firewall down but just to add the following exceptions on the client ?
In order to successfully use client push to install the Configuration Manager 2007 client, you must add the following as exceptions to the Windows Firewall:
File and Printer Sharing
Windows Management Instrumentation (WMI)
I totally agree with you. I would much prefer to be able to manually push the client out in several waves, but I am yet to find a way to add WMI as a firewall exception on windows XP clients.
I did find this link, but it didn't seem to work when I first tried it.
http://support.microsoft.com/kb/875605
I think I found our problem.
When the client is going to install it is looking for the sitename Default-First-Site-Name, which is how our SMS 2003 server was setup. HOwever, that is not how the boundary is set in SCCM 2007. How do I point it at the right place? Why is it going after the old site? I verified that SCCM published properly to AD's system management container.
<![LOG[==========[ ccmsetup started in process 2008 ]==========]LOG]!><time="19:00:15.612+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:8849">
<![LOG[Version: 4.0.6221.1000]LOG]!><time="19:00:15.612+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:1907">
<![LOG[GetAdaptersAddressess entry point is supported.]LOG]!><time="19:00:15.612+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="ccmiputil.cpp:118">
<![LOG[DhcpGetOriginalSubnetMask entry point not supported.]LOG]!><time="19:00:15.628+240" date="03-25-2010" component="ccmsetup" context="" type="2" thread="3780" file="ccmiputil.cpp:169">
<![LOG[Adapter {08232EFD-60A5-4CBF-BD26-615B9EC29DC9} is DHCP enabled. Checking quarantine status.]LOG]!><time="19:00:15.628+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="ccmiputil.cpp:509">
<![LOG[Current AD site of machine is Default-First-Site-Name]LOG]!><time="19:00:15.628+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="lsad.cpp:457">
<![LOG[Attempting to query AD for assigned site code]LOG]!><time="19:00:15.628+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="lsad.cpp:1766">
<![LOG[Executing query (&(ObjectCategory=MSSMSRoamingBoundaryRange)(|(&(MSSMSRangedIPLow<=169871576)(MSSMSRangedIPHigh>=169871576))))]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="lsad.cpp:1801">
<![LOG[Executing query (&(ObjectCategory=mSSMSSite)(|(mSSMSRoamingBoundaries=10.32.8.0)(mSSMSRoamingBoundaries=Default-First-Site-Name)))]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="lsad.cpp:1862">
<![LOG[Command line: "C:\WINDOWS\SoftwareDistribution\Download\Install\ccmsetup.exe" ]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:3941">
<![LOG[Ccmsetup was run without any user parameters specified. Assume AUTO sitecode and run without registering ccmsetup as a service.]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:3959">
<![LOG[CCMHTTPPORT: 80]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:7847">
<![LOG[CCMHTTPSPORT: 443]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:7862">
<![LOG[CCMHTTPSSTATE: 2147483648]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:7880">
<![LOG[CCMHTTPSCERTNAME: ]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:7908">
<![LOG[FSP: ]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:7923">
<![LOG[No MP or source location has been explicitly specified. Trying to discover a valid content location...]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:4271">
<![LOG[Current directory is not a valid source location.]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:4288">
<![LOG[Looking for an MP source through SLP...]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:4303">
<![LOG[iPv6 entry points already initialized.]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="ccmiputil.cpp:75">
<![LOG[DHCP entry points already initialized.]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="ccmiputil.cpp:139">
<![LOG[Adapter {08232EFD-60A5-4CBF-BD26-615B9EC29DC9} is DHCP enabled. Checking quarantine status.]LOG]!><time="19:00:15.800+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="ccmiputil.cpp:509">
<![LOG[Current AD site of machine is Default-First-Site-Name]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="lsad.cpp:457">
<![LOG[Attempting to query AD for assigned site code]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="lsad.cpp:1766">
<![LOG[Executing query (&(ObjectCategory=MSSMSRoamingBoundaryRange)(|(&(MSSMSRangedIPLow<=169871576)(MSSMSRangedIPHigh>=169871576))))]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="lsad.cpp:1801">
<![LOG[Executing query (&(ObjectCategory=mSSMSSite)(|(mSSMSRoamingBoundaries=10.32.8.0)(mSSMSRoamingBoundaries=Default-First-Site-Name)))]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="0" thread="3780" file="lsad.cpp:1862">
<![LOG[Couldn't find an MP source through SLP.]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:4315">
<![LOG[No valid source or MP locations could be indentified to download content from.Ccmsetup.exe cannot continue.]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="3" thread="3780" file="ccmsetup.cpp:4326">
<![LOG[invalid ccmsetup command line: "C:\WINDOWS\SoftwareDistribution\Download\Install\ccmsetup.exe" ]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="3" thread="3780" file="ccmsetup.cpp:4405">
<![LOG[A Fallback Status Point has not been specified. Message with STATEID='100' will not be sent.]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:9169">
<![LOG[A Fallback Status Point has not been specified. Message with STATEID='307' will not be sent.]LOG]!><time="19:00:15.815+240" date="03-25-2010" component="ccmsetup" context="" type="1" thread="3780" file="ccmsetup.cpp:9169">
in your site settings, how are your boundaries setup for this site ?
the new site is an active directory site with the site name as our domain name.
Just out of curiosity, I tried manually installing the client on another machine with the following command:
ccmsetup.exe /mp:SCCM SMSSITECODE=XXX, where SCCM is our Site Server and MP, and XXX is our sitename, and it went and uninstalled the old client, installed the new one, and now reports to the site properly.
In the systems management container of AD, it looks like everything is right. It lists:
-SMS-MP-XXX-SCCM
-SMS-Site-XXX
-SMS-SLP-XXX-SCCM
I even tried re-publishing the site, and all 3 attributes returned shortly after doing so.
So the question is, why won't machines on the domain see it?
