evanl
Run advertised programs questions
I followed the procedures as outlined here to capture and upload. I was glad that I reached to the point where I saw the program listed in the run advertised programs. As soon as I run the program, a message box indicated that it was searching for a program file and the box disappeared and nothing happens. I cannot get pass this point. Please offer some suggestions to resolve this? Thank you.
6 answers to this question
what does execmgr.log and CAS.Log says ?
There is a lot of data I saw on those 2 log files. I am not sure exactly what to look for. For the execmgr.log file, at the end it indicated that it failed with exit code 87. As for the CAS.log, I cannot find anything that indicated failure or similar. What should I look for specifically in these log files to help resolve this problem? Thanks.
Anyone else have any solutions to this problem, I followed all the steps as outlined "How can I capture Windows 7 using a custom Task Sequence". Once I run the program on RAP, a window popped up for a split second saying searching for program files. What did I miss?
