Bergy
DNS or Discovery Problem
I have 2 Windows 2008 R2 servers in a lab. We don't use DHCP. The DC has Active Directory, DNS, IIS and WSUS 3.0 SP2. The SCCM server has IIS, WSUS(just the admin part) and SCCM 2007SP2. I can't get the Active Directory Discovery methods to work. I am logged in as a local admin and when I am in the Active Directory System Discovery Properties and I click the star to add the active directory containers, Configuration Manager crashes and tells me the "Current security context is not associated with an Active Directory". I did add a reverse lookup in DNS. I can ping the servers by name and IP. I am also getting a DNS error 4013 that the "DNS server is waiting for Active Directory Domain Services to signal that the initial synchronization of the directory has been completed". Any help would be much appreciated.
Thank you
Check your DNS settings. Make sure you are able to make DNS queries from your SCCM machine.
Easiest way is to just ping your domain name from your sccm server (make sure firewalls are not blocking this trafik..)
