using SCCM 2012 in a LAB - Part 4. Configuring Client Settings and adding roles
I am having the same issue. It appears that the client is installed. However in the Config Manager it still says Client = No. When i try to open the Software Center on the client machine i get the popup: "Software Center can not be loaded. There is a problem loading the required components for Software Center. You can try launching Software Center at a later time. If the problem continues, you can contact your helpdesk.
When I click on the find applications from the app catalog I get a prompt to enter a username and password? Why is that?
I had better luck by setting the intranet zone instead of the trusted sites zone on a "hardened" IE setup.
Windows Server since 2003 has this hardened mode for Internet Explorer that disables the majority of scripting and add-ons if you're foolhardy enough to go web surfing on your production server. IE8 and IE9 have stricter controls on "Trusted Sites" than previous versions; they're closer to the "Internet Zone" settings from IE6.
To make Application Center work I instead added my AD domain (*.example.com) to my Intranet Zone using Group Policy, rather than use the "Add site to Trusted Sites" switch. This works for any other local web servers, even non-Microsoft ones, that require scripting, pop-ups and so on to work.
<![LOG[==========[ ccmsetup started in process 20032 ]==========]LOG]!><time="09:01:09.106-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:8727">
<![LOG[Version: 5.0.7678.0000]LOG]!><time="09:01:09.128-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:533">
<![LOG[Running on OS (6.1.7601). Service Pack (1.0). SuiteMask = 256. Product Type = 1]LOG]!><time="09:01:09.128-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:666">
<![LOG[Command line: "C:\Windows\ccmsetup\ccmsetup.exe" /runservice /config:MobileClient.tcf]LOG]!><time="09:01:09.128-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:2984">
<![LOG[CCMHTTPPORT: 80]LOG]!><time="09:01:09.139-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:7953">
<![LOG[CCMHTTPSPORT: 443]LOG]!><time="09:01:09.139-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:7968">
<![LOG[CCMHTTPSSTATE: 224]LOG]!><time="09:01:09.139-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:7986">
<![LOG[CCMHTTPSCERTNAME: ]LOG]!><time="09:01:09.139-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:8004">
<![LOG[FSP: ]LOG]!><time="09:01:09.139-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:8056">
<![LOG[CCMFIRSTCERT: 1]LOG]!><time="09:01:09.139-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:8114">
<![LOG[unable to open Registry key Software\Microsoft\CCM. Return Code [80070002]. Client HTTPS state is Unknown.]LOG]!><time="09:01:09.140-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmutillib.cpp:326">
<![LOG[CCMCERTID: SMS;4E6AD9063B80D6DB70BCFD643BB7DD3E2200C23B]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="0" thread="19368" file="ccmsetup.cpp:8135">
<![LOG[Config file: C:\Windows\ccmsetup\MobileClientUnicode.tcf]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3634">
<![LOG[Retry time: 10 minute(s)]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3635">
<![LOG[MSI log file: ]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3636">
<![LOG[MSI properties: INSTALL=ALL" SMSSITECODE="PCB" CCMHTTPPORT="80" CCMHTTPSPORT="443" CCMHTTPSSTATE="224" CCMFIRSTCERT="1" CCMCERTID="SMS;4E6AD9063B80D6DB70BCFD643BB7DD3E2200C23B]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3637">
<![LOG[source List:]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3645">
<![LOG[ <a href="file://\servernameSMSClient]LOG]!><time="09:01:09.145-60">\\servername\SMSClient]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3652">
<![LOG[ <a href="file://\servernameSMSClient]LOG]!><time="09:01:09.145-60">\\servername\SMSClient]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3661">
<![LOG[MPs:]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3664">
<![LOG[ servername]LOG]!><time="09:01:09.145-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:3679">
<![LOG[Detected client version 2.50.4253.3000 from WMI.]LOG]!><time="09:01:09.198-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:752">
<![LOG[upgrade from the existing client version '2.50.4253.3000' is not supported. The minimum version required to upgrade the client is '4.0.5931.0'.]LOG]!><time="09:01:09.198-60" date="12-12-2011" component="ccmsetup" context="" type="3" thread="19368" file="ccmsetup.cpp:763">
<![LOG[A Fallback Status Point has not been specified. Message with STATEID='100' will not be sent.]LOG]!><time="09:01:09.198-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:9055">
<![LOG[A Fallback Status Point has not been specified. Message with STATEID='320' will not be sent.]LOG]!><time="09:01:09.198-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:9055">
<![LOG[CcmSetup is exiting with return code 0]LOG]!><time="09:01:09.198-60" date="12-12-2011" component="ccmsetup" context="" type="1" thread="19368" file="ccmsetup.cpp:10040">
interesting look at this
that's an SMS 2003 SP3 client ! not supported,
are you using SCCM 2012 RC to upgrade old clients or what ?
uninstall it and try again
niall
