Kevin79
Problem with secondary server
I recently installed a secondary server for a new site (12th secondary server installed) and am having issues with it. I installed it using the DVD and patched it to R3 so it is the same version that my primary site is running. I had to manually do the key exchange on the primary and new secondary server before the server would show up in the SCCM console. The secondary server shows as "active" too. However, when I go to look at the properties of the secondary server, I get "The ConfigMgr Provider reported an error." If I expand the details I get
ConfigMgr Error Object:
instance of __ExtendedStatus
Operation = "GetObject";
ParameterInfo = "SMS_SCI_Component.FileType=2,ItemName=\"SMS_MP_CONTROL_MANAGER|SMS Management Point\",ItemType=\"Component\",SiteCode=\"JAG\"";
ProviderName = "WinMgmt";
Error Code:
NotFound
Any idea's how to fix this?
