Sign in to follow this
emmo16
MDT 2012 UDI Wizard Designer and SCCM 2007 help
We are currently upgrading over 5000 pc's and laptops to Win7 using SCCM 2007 and a FrontEnd HTA for selecting software . At the moment there is a different task sequence for every department.
I have been looking into using one task sequence and a HTA to select department and Ou computer name ect. So far I just have the HTA allowing users to select and install software. Its a work in progress.
Today I have just discovered UDI Wizard Designer in MDT 2012. Can anyone tell me if it is is possible to use this in SCCM 2012 to build a task sequence and if there are any tutorials out there on how todo that. It looks a lot easier than using a HTA and formatting that when you want to make a change and has all the bits we need to select.
We would like to let are deployment team select if they are building a pc or laptop with bitlocker, to choose the dept, OU and software
Any help would be great.
