winterwy
SCCM 2012 error 0x80070002 when apply and capture OS
THank you for your informaion!
yes, you are right. I checked wrong smsts.log.
I just attached updated smsts.log.
its error is http result:401
SendResourceRequest() failed with 0x80004005
I still cannot figure it out. could you please help?
Thanks again.
I am running into the issue and I only have 2 sites listed in IIS, Default Web Site and WSUS and both are set to Anonyoums Authentication.
I even deleted the OS folders for the operating systems, and recreated them. Deleted and recreated the OS Installers and Task Sequences but it still gives me the error when applying the OS.
I would appreciate any additional help with this.
smsts.log
