trhg
Problem with SCCM agent
I have a problem with the CCM agent.
there is a lot of computer that haven't got the CCM agent installed. When i try to install it manually i get.
No valid source or MP locations could be indentified to download content from.Ccmsetup.exe cannot continue.
==========[ ccmsetup started in process 5536 ]========== ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Version: 4.0.6487.2000 ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
LSGetAssignedSiteFromAD ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
GetAdaptersAddressess entry point is supported. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
DhcpGetOriginalSubnetMask entry point is supported. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Adapter {883853BC-2ADA-4697-90DC-9471B54AC28B} is DHCP enabled. Checking quarantine status. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Adapter {883853BC-2ADA-4697-90DC-9471B54AC28B} has 0 IPv4 address(es). ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Adapter {8F421327-3343-40B1-A066-3B0835DB42A5} is DHCP enabled. Checking quarantine status. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Adapter {8F421327-3343-40B1-A066-3B0835DB42A5} has 0 IPv4 address(es). ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Adapter {17D15F3F-6F91-4A0A-AD66-CDE3DC404A01} is DHCP enabled. Checking quarantine status. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Adapter {17D15F3F-6F91-4A0A-AD66-CDE3DC404A01} has 1 IPv4 address(es). ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
LSGetADSiteName ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Current AD site of machine is Intern ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Attempting to query AD for assigned site code ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
ulFetched == 1, HRESULT=80004005 (e:\nts_sms_fre\sms\framework\locationservices\lsutilities\lsad.cpp,1780) ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Command line: "C:\ccmsetup.exe" ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Ccmsetup was run without any user parameters specified. Assume AUTO sitecode and run without registering ccmsetup as a service. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
CCMHTTPPORT: 80 ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
CCMHTTPSPORT: 443 ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
CCMHTTPSSTATE: 2147483648 ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
CCMHTTPSCERTNAME: ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
FSP: ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
No MP or source location has been explicitly specified. Trying to discover a valid content location... ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Current directory is not a valid source location. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Looking for an MP source through SLP... ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
IPv6 entry points already initialized. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
DHCP entry points already initialized. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
LSGetAssignedSiteFromAD(sSiteCode), HRESULT=80004005 (e:\nts_sms_fre\sms\setup\ccmsetup\ccmsetup.cpp,5788) ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Couldn't find an MP source through SLP. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
No valid source or MP locations could be indentified to download content from.Ccmsetup.exe cannot continue. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
Invalid ccmsetup command line: "C:\ccmsetup.exe" ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
CFSPStateMessage::CFSPStateMessage FSPStateMessage 02.11.2012 10:11:57 5548 (0x15AC)
CFSPStateMessage::IsFSPHostSet FSPStateMessage 02.11.2012 10:11:57 5548 (0x15AC)
A Fallback Status Point has not been specified. Message with STATEID='100' will not be sent. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
CFSPStateMessage::~CFSPStateMessage FSPStateMessage 02.11.2012 10:11:57 5548 (0x15AC)
A Fallback Status Point has not been specified. Message with STATEID='307' will not be sent. ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
ParseCommandLine(), HRESULT=80004005 (e:\nts_sms_fre\sms\setup\ccmsetup\ccmsetup.cpp,2193) ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
g_CcmSetup->WinMain(), HRESULT=80004005 (e:\nts_sms_fre\sms\setup\ccmsetup\ccmsetup.cpp,9862) ccmsetup 02.11.2012 10:11:57 5548 (0x15AC)
What can the reason be ? this happen when we implemented a new SCCM 2007 Hierarchy.
We set the Site code via GPO
We have AD Site and IP subnet boundary
we have a total of 3 servers. 1 master (CSM) and 2 sites( CMA and CMB) . all running
w2k8R2 sp1
tried to uninstall the client manually but when i try to install it i get the same error..
ill provide more info if needed :)!
The client cannot find a boundary from the AD that it is assigned to and if you run ccmsetup.exe without any switches the computer must be within a boundary. Assigning the Site Code via GPo only works when installing the ccmsetup.msi using a group policy.
Regards,
Jörgen
Regards,
Jörgen
Regards,
Jörgen
Hi, i run with these command lines "c:\windows\system32\ccmsetup\ccmsetup.exe /mp:adm14 /forcereboot"
Now it installs the CCM agent BUT, it doesn't update in the config manager that the computer has a agent installed.
Any other ideas to things i can try ?
