Mateo
MDT MMC Problem
Hi, Suddenly I'm unable to open/edit an existing Task Sequence in MDT 2010 Update 1.
I click properties on the Task Sequence then click the "Task Sequence" or "OS Info" tab then get an "MMC has detected an error in a snap-in and will unload it".
I can click those two tabs on the properties of other Task Sequences and not get the MMC message.
Any advice would be greatly appreciated.
Thanks!
