Help; Deploy package with user logon Not Run. how the process works? .. Help please.
Hello friends, this forum is important to me.
I am new to Config. Manager, I am doing a deploy of a package lync when the user logon, but does not work. The package is copied to the client cache is discovered, I forced the policy, restart the computer and run the deployment.
I can say I'm hacieno wrong? I do not see. I have weeks and not solve! I want to start the first session after the deployment deploy run. it is Possible
. I hope for several hours, restart and nothing.
This as required and when starting Session. and nothing.
How do I run the package the next reboot when the user logs Session?
Heeeeeeeellllllpppp..How does this work?
APPDISCOVERY.LOG
<![LOG[Entering ExecQueryAsync for query "select * from CCM_AppDeliveryType where (AppDeliveryTypeId = "ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61" AND Revision = 1)"]LOG]!><time="11:28:53.685+270" date="08-31-2013" component="AppDiscovery" context="" type="1" thread="668" file="appprovider.cpp:401">
<![LOG[ Performing detection of app deployment type Lync(ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, revision 1) for system.]LOG]!><time="11:28:53.725+270" date="08-31-2013" component="AppDiscovery" context="" type="1" thread="668" file="appprovider.cpp:2079">
<![LOG[+++ Application not discovered. [AppDT Id: ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, Revision: 1]]LOG]!><time="11:28:53.794+270" date="08-31-2013" component="AppDiscovery" context="" type="1" thread="668" file="localapphandler.cpp:291">
<![LOG[+++ Did not detect app deployment type Lync(ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, revision 1) for system.]LOG]!><time="11:28:53.795+270" date="08-31-2013" component="AppDiscovery" context="" type="1" thread="668" file="appprovider.cpp:514">
<![LOG[ ActionType - Install will use Content Id: Content_40504a71-95d9-49d3-9c00-df0d1c2e2f2f + Content Version: 1 for AppDT "Lync" [scopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61], Revision - 1]LOG]!><time="11:28:54.502+270" date="08-31-2013" component="AppDiscovery" context="" type="1" thread="668" file="appprovider.cpp:1486"><![LOG[Entering ExecQueryAsync for query "select * from CCM_AppDeliveryType where (AppDeliveryTypeId = "ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61" AND Revision = 1)"]LOG]!><time="11:28:53.685+270" date="08-31-2013" component="AppDiscovery" context="" type="1" thread="668" file="appprovider.cpp:401">
APPENFORCE.LOG
Working directory: ]LOG]!><time="08:00:04.320+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appcontext.cpp:84">
<![LOG[ Prepared working directory: C:\Windows\ccmcache\8]LOG]!><time="08:00:04.320+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appcontext.cpp:188">
<![LOG[ Prepared command line: "C:\Windows\ccmcache\8\Lync.exe"]LOG]!><time="08:00:04.320+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appcontext.cpp:337">
<![LOG[ Executing Command line: "C:\Windows\ccmcache\8\Lync.exe" with user context]LOG]!><time="08:00:04.320+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appexcnlib.cpp:201">
<![LOG[ Working directory C:\Windows\ccmcache\8]LOG]!><time="08:00:04.320+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appexcnlib.cpp:215">
<![LOG[ Post install behavior is BasedOnExitCode]LOG]!><time="08:00:04.399+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appcommon.cpp:1093">
<![LOG[ Waiting for process 4600 to finish. Timeout = 120 minutes.]LOG]!><time="08:00:04.399+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appexcnlib.cpp:1951">
<![LOG[ Process 4600 terminated with exitcode: 0]LOG]!><time="08:00:04.617+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appexcnlib.cpp:1960">
<![LOG[ Looking for exit code 0 in exit codes table...]LOG]!><time="08:00:04.617+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appexcnlib.cpp:505">
<![LOG[ Matched exit code 0 to a Success entry in exit codes table.]LOG]!><time="08:00:04.617+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appexcnlib.cpp:584">
<![LOG[ Performing detection of app deployment type Lync(ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, revision 1) for system.]LOG]!><time="08:00:04.617+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appprovider.cpp:2079">
<![LOG[+++ Application not discovered. [AppDT Id: ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, Revision: 1]]LOG]!><time="08:00:04.633+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="localapphandler.cpp:291">
<![LOG[++++++ App enforcement completed (0 seconds) for App DT "Lync" [scopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61], Revision: 1, User SID: ] ++++++]LOG]!><time="08:00:04.633+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="6084" file="appprovider.cpp:2366">
<![LOG[+++ Starting Install enforcement for App DT "Lync" ApplicationDeliveryType - ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, Revision - 1, ContentPath - C:\Windows\ccmcache\a, Execution Context - System]LOG]!><time="11:31:32.074+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appprovider.cpp:1643">
<![LOG[ A user is logged on to the system.]LOG]!><time="11:31:32.104+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appprovider.cpp:2014">
<![LOG[ Performing detection of app deployment type Lync(ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, revision 1) for system.]LOG]!><time="11:31:32.124+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appprovider.cpp:2079">
<![LOG[+++ Application not discovered. [AppDT Id: ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, Revision: 1]]LOG]!><time="11:31:32.195+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="localapphandler.cpp:291">
<![LOG[ App enforcement environment:
Context: Machine
Command line: Lync.exe
Allow user interaction: Yes
UI mode: 1
User token: null
Session Id: 4294967295
Content path: C:\Windows\ccmcache\a
Working directory: ]LOG]!><time="11:31:32.229+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appcontext.cpp:84">
<![LOG[ Prepared working directory: C:\Windows\ccmcache\a]LOG]!><time="11:31:32.230+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appcontext.cpp:188">
<![LOG[ Prepared command line: "C:\Windows\ccmcache\a\Lync.exe"]LOG]!><time="11:31:32.232+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appcontext.cpp:337">
<![LOG[ Executing Command line: "C:\Windows\ccmcache\a\Lync.exe" with user context]LOG]!><time="11:31:32.239+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appexcnlib.cpp:201">
<![LOG[ Working directory C:\Windows\ccmcache\a]LOG]!><time="11:31:32.239+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appexcnlib.cpp:215">
<![LOG[ Post install behavior is BasedOnExitCode]LOG]!><time="11:31:32.305+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appcommon.cpp:1093">
<![LOG[ Waiting for process 1556 to finish. Timeout = 120 minutes.]LOG]!><time="11:31:32.308+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appexcnlib.cpp:1951">
<![LOG[ Process 1556 terminated with exitcode: 0]LOG]!><time="11:31:32.667+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appexcnlib.cpp:1960">
<![LOG[ Looking for exit code 0 in exit codes table...]LOG]!><time="11:31:32.667+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appexcnlib.cpp:505">
<![LOG[ Matched exit code 0 to a Success entry in exit codes table.]LOG]!><time="11:31:32.668+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appexcnlib.cpp:584">
<![LOG[ Performing detection of app deployment type Lync(ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, revision 1) for system.]LOG]!><time="11:31:32.678+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appprovider.cpp:2079">
<![LOG[+++ Application not discovered. [AppDT Id: ScopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61, Revision: 1]]LOG]!><time="11:31:32.696+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="localapphandler.cpp:291">
<![LOG[++++++ App enforcement completed (0 seconds) for App DT "Lync" [scopeId_CE20042C-68E0-4552-AB76-907F205D3CDB/DeploymentType_6b92b651-1aa7-4ea7-8897-e28967c4fc61], Revision: 1, User SID: ] ++++++]LOG]!><time="11:31:32.698+270" date="08-31-2013" component="AppEnforce" context="" type="1" thread="1368" file="appprovider.cpp:2366">
APPENFORCE No reference to the current package, if not deployed before
exemgr.log
![LOG[Requesting MTC to delete task with id: ]LOG]!><time="21:56:33.419+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1920" file="executionrequest.cpp:9007">
<![LOG[This execution request does not own the corresponding task in MTC, returning without deleting it from MTC.]LOG]!><time="21:56:33.419+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1920" file="executionrequest.cpp:9018">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 45l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:33.424+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1920" file="event.cpp:396">
<![LOG[Policy arrived for parent package EN00030 program Lync]LOG]!><time="21:56:33.717+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1920" file="execreqmgr.cpp:6894">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 6l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:33.721+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1920" file="event.cpp:396">
<![LOG[Raising event:
[sMS_CodePage(850), SMS_LocaleID(3082)]
instance of SoftDistProgramOfferReceivedEvent
AdvertisementId = "EN20025";
ClientID = "GUID:13F977CF-03D2-4036-B144-EB422C8B0C96";
DateTime = "20130901022633.734000+000";
MachineName = "pcclient";
ProcessID = 2628;
SiteCode = "lab";
ThreadID = 1920;
]LOG]!><time="21:56:33.734+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1920" file="event.cpp:706">
<![LOG[Requesting content from CAS for package EN00030 version 1]LOG]!><time="21:56:33.762+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="contentaccesshelper.cpp:246">
<![LOG[successfully created a content request handle {2F221190-068F-4FAE-8A34-68A310B6E6A2} for the package VEN00030 version 1]LOG]!><time="21:56:33.871+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="contentaccesshelper.cpp:331">
<![LOG[Program Lync change to state STATE_ADVANCED_DOWNLOAD content in progress]LOG]!><time="21:56:33.871+270" date="08-31-2013" component="execmgr" context="" type="2" thread="2928" file="executionrequest.cpp:3669">
<![LOG[Execution Request for advert EN20025 package EN00030 program Lync state change from NotExist to AdvancedDownload]LOG]!><time="21:56:33.871+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="executionrequest.cpp:501">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:33.871+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:33.996+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:34.206+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2116" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:34.919+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:35.608+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2116" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:56:37.417+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2116" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:10.104+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1648" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:17.023+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1648" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:18.841+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2444" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:22.157+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1648" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:39.251+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:46.138+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:57:56.901+270" date="08-31-2013" component="execmgr" context="" type="1" thread="3684" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:58:06.130+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="VEN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:58:07.581+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:58:15.368+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="EN00030",ProgramID="Lync", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l]LOG]!><time="21:58:29.303+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2928" file="event.cpp:396">
<![LOG[ Processing [{2F221190-068F-4FAE-8A34-68A310B6E6A2}, 0]: OnContentAvailable ]LOG]!><time="21:59:17.968+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2116" file="contentavailablehandletask.cpp:156">
<![LOG[[{2F221190-068F-4FAE-8A34-68A310B6E6A2}]: Content Version 1 is available for advert EN20025, pkg: EN00030, program Lync.]LOG]!><time="21:59:18.065+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2116" file="executionrequest.cpp:4909">
<![LOG[ Processing [{2F221190-068F-4FAE-8A34-68A310B6E6A2}, 0]: RemoveNotification]LOG]!><time="21:59:18.066+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2116" file="contentavailablehandletask.cpp:164">
<![LOG[The user has logged off.]LOG]!><time="22:02:50.613+270" date="08-31-2013" component="execmgr" context="" type="1" thread="2812" file="execreqmgr.cpp:5139">
<![LOG[Failed to open to WMI namespace '\\.\root\ccm\Policy\Machine' (8007045b)]LOG]!><time="22:02:53.719+270" date="08-31-2013" component="execmgr" context="" type="3" thread="1340" file="wminamespace.cpp:292">
<![LOG[Failed to ConnectSettings for ICcmPolicyAgent in CSoftDistPolicyNamespace::ConnectToNamespace]LOG]!><time="22:02:53.719+270" date="08-31-2013" component="execmgr" context="" type="3" thread="1340" file="softdistpolicy.cpp:3399">
<![LOG[Failed to ConnectToNamespace in CSoftDistPolicyNamespace::GetMachinePolicy]LOG]!><time="22:02:53.719+270" date="08-31-2013" component="execmgr" context="" type="3" thread="1340" file="softdistpolicy.cpp:3513">
<![LOG[Failed to connect to machine policy name space. 0x8007045b]LOG]!><time="22:02:53.719+270" date="08-31-2013" component="execmgr" context="" type="2" thread="1340" file="softdistpolicy.cpp:2523">
<![LOG[Failed to connect to user policy name space]LOG]!><time="22:02:53.719+270" date="08-31-2013" component="execmgr" context="" type="2" thread="1340" file="softdistpolicy.cpp:2538">
<![LOG[CSoftwareDistPolicyMgr::GetSWDistSiteSettings failed to connect to machine namespace]LOG]!><time="22:02:53.719+270" date="08-31-2013" component="execmgr" context="" type="3" thread="1340" file="softdistpolicy.cpp:1384">
<![LOG[A user has logged on.]LOG]!><time="22:06:06.759+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1536" file="execreqmgr.cpp:4912">
<![LOG[The logged on user is DOMAIN\TESTUSER]LOG]!><time="22:06:06.901+270" date="08-31-2013" component="execmgr" context="" type="1" thread="1536" file="execreqmgr.cpp:4931">
Hi Fray
Does lync require an install for every user that logs on?
Is a lync installation on a system not for everyone to use that uses the system?
In my environment Lync is installed at OSD time along with the other office 2013 applications as an Office package in full. There could be as many as 100 users that may use the same machine and the one install of Lync does everyone who visits that machine.
I know that this is not the same for you as you need to get Lync deployed now after OSD time but I see that you have configured it to run once for every user that logs on.... would this be appropriate.
Is this a package you have created or an application according to your screen shots above I think it's a package. Applications are far more user-centric than packages are and also have alot more functionality. To what are you deploying the package of Lync to, systems or users collections?
Hello Rocket man, thanks for Reply.
In our environment even have office 2010, and Lync 2013 are only migrating independently, not with office 2013.
Alway Rerun Program, is for the laboratory need the package or the application is executed when the user logon, but does not work.
