help on reports sccm2012
hello
I want to give you my appologize for my horrible english ( i'm french)
I need help for a report on sccm2012
i want to create a report for view the state of application deployement for one user (success, error,requierement not met, unknown)
could you help me please ?
  • 3 weeks later...
Hello again
i made this report
SELECT
vAppDeploymentAssetDetails.MachineName
,vAppDeploymentAssetDetails.UserName
,vAppDeploymentAssetDetails.CollectionName
,vAppDeploymentAssetDetails.StatusType
From
where
vAppDeploymentAssetDetails.MachineName LIKE @variable
in the query designer it works but on sccm 2012 i have an error
Could you help me ?
Microsoft.Reporting.WinForms.ReportServerException
Une erreur s'est produite lors du traitement du rapport. (rsProcessingAborted)
Stack Trace:
at Microsoft.Reporting.WinForms.ServerReport.ServerUrlRequest(Boolean isAbortable, String url, Stream outputStream, String& mimeType, String& fileNameExtension)
at Microsoft.Reporting.WinForms.ServerReport.InternalRender(Boolean isAbortable, String format, String deviceInfo, NameValueCollection urlAccessParameters, Stream reportStream, String& mimeType, String& fileNameExtension)
at Microsoft.Reporting.WinForms.AsyncMainStreamRenderingOperation.RenderServerReport(ServerReport report)
at Microsoft.Reporting.WinForms.AsyncRenderingOperation.PerformOperation()
at Microsoft.Reporting.WinForms.ReportViewer.AsyncReportOperationWrapper.PerformOperation()
at Microsoft.Reporting.WinForms.ProcessingThread.ProcessThreadMain(Object arg)
Échec de l'exécution de la requête pour le dataset 'DataSet1'. (rsErrorExecutingCommand)
Stack Trace:
Pour obtenir plus d'informations sur cette erreur, accédez au serveur de rapports sur le serveur local ou activez les erreurs distantes.
Stack Trace:
yes in the query designer it works
and thanks for your help :)
  • 2 months later...
i made a new report : it works and i hope it will help you
select Distinct
DSC.CollectionName,
DSC.SoftwareName,
 fc.Name,
CASE
WHEN (dbo.fn_GetAppState(ad.ComplianceState, ad.EnforcementState, cia.OfferTypeID, 1, ad.DesiredState, ad.IsApplicable) / 1000 = '1') THEN 'success'
WHEN (dbo.fn_GetAppState(ad.ComplianceState, ad.EnforcementState, cia.OfferTypeID, 1, ad.DesiredState, ad.IsApplicable) / 1000 = '2') THEN 'in progress'
WHEN (dbo.fn_GetAppState(ad.ComplianceState, ad.EnforcementState, cia.OfferTypeID, 1, ad.DesiredState, ad.IsApplicable) / 1000 = '3') THEN 'requierement not met'
WHEN (dbo.fn_GetAppState(ad.ComplianceState, ad.EnforcementState, cia.OfferTypeID, 1, ad.DesiredState, ad.IsApplicable) / 1000 = '4') THEN 'inactif'
WHEN (dbo.fn_GetAppState(ad.ComplianceState, ad.EnforcementState, cia.OfferTypeID, 1, ad.DesiredState, ad.IsApplicable) / 1000 = '5') THEN 'error'
ELSE 'error sql'
END 'status',
datediff(day,WS.LastActiveTime,getdate()) as date
FROM fn_rbac_DeploymentSummary(dbo.fn_LShortNameToLCID(@locale), @UserSIDs) DSC
RIGHT OUTER JOIN fn_rbac_FullCollectionMembership(@UserSIDs) as fc on fc.CollectionID = DSC.CollectionID AND DSC.FeatureType = 1
LEFT JOIN fn_rbac_AppIntentAssetData(@UserSIDs) ad ON ad.MachineID = fc.ResourceID AND ad.AssignmentID = DSC.AssignmentID
INNER JOIN fn_rbac_CIAssignment(@UserSIDs) cia ON cia.AssignmentID = DSC.AssignmentID
LEFT OUTER JOIN v_CombinedDeviceResources WS ON fc.ResourceID = WS.MachineID
where fc.ResourceType = 5 AND fc.Name = @poste
sorry but i can't answer to you
i made this report by trying lot of sql table
i don't have any experience in SCCM or SRSS and i don't know RBA
but i really want to learn if you have any book or tutorial i will be gratefull
