t0meck
Console Only installation - Remote Control not working
Hello
I've found out that I have a problem using Remote Control. When I try to connect to managed domain-joined machine the connection hangs up at the "Connecting to the host session" step.
After a while a message is logged to RC console "Viewer disconnected".
Now the configuration:
Win2k8r2 server - management server host
SCCM2012 CU3 server
RC console - works ok
Win2k12r2 RC??? - management host
SCCM2012 CU3 admin console only installation
RC console - cannot connect to host
Win7x64 SP1 - managed host (domain joined)
SCCM2012 client running
RC service started
When I try to connect to win7 host from my server, everything works just fine. But when I try to connect to the same host from management host which runs only sccm 2012 cu3 admin console I cannot connect.
Now. What can I do to connect to my host from my management host to my win7 host via RC console?
Is it not working due to the fact that I'm running console on 2012 r2 RC server system which might be unsupported by sccm 2012 cu3 or the fact that I need to configure something to enable connection also from my management host beside my management server host?
Please help.
Tom.
