Showing results for tags 'CM 2012'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 3 results
  1. I wanted to put this topic in the main CM2012 forum, but I can't, for some reason. That's why it's posted here. Hello, I was really hoping someone could help me with this. Background information: - We have a CM07 server in a production environment. - I've set up a CM12 RTM server, following the guides in this forum, with the hopes of migrating soon. - I wanted to do OSD from scratch to learn more and to take advantage of new features in CM12. - I have a few virtual machines running for testing OSD/apps (these are the only clients managed by my CM12 server). - Since it's not possible to have two WDS servers running at the same time AFAIK (without using registry tweaks, the F11 trick, that by the way doesn't work for me) I have created a bootable TS media that I mount on the virtual machines whenever I want to test OSD. Now, to my problem: I can't figure out why my Build and Capture TS is failing on the Install Software Updates step. smsts.log file says: Failed to RefreshUpdates, hr=087d00272, followed by: Failed to run the action: Install Software Updates. Component is disabled (Error: 87D00272; Source: CCM). I have read about similar issues occurring in CM07 capture task sequences since the machine is joined to a Workgroup. The proposed solution was adding SMSSLP=FQDN to the client installation properties, but since that functionality is moved to the MP in CM12, it should be enough to specify SMSMP=FQDN in my case. It's not working anyway. Tried it to a Deploy TS also, where the machine is domain joined, but I got the same error. The error code 87D00272 returns no results on Google. This stumps me, as someone surely has had the same problem? Here is the relevant portions of the smsts.log file If someone had the chance to look at this, I would greatly appreciate it. Thank you! Refreshing Updates InstallSWUpdate 2012-06-13 10:15:33 228 (0x00E4) spInstall->RefreshTargetedUpdates( spCallback, &bAlreadyCompleted ), HRESULT=87d00272 (e:\nts_sccm_release\sms\client\osdeployment\installswupdate \installswupdate.cpp,467) InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) Failed to RefreshUpdates, hr=0x87d00272 InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) RefreshTargetedUpdates(spInstall, spCallback, bAlreadyCompleted), HRESULT=87d00272 (e:\nts_sccm_release\sms\client\osdeployment\installswupdate \installswupdate.cpp,1295) InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) RefreshUpdates(), HRESULT=87d00272 (e:\nts_sccm_release\sms\client\osdeployment \installswupdate\installswupdate.cpp,906) InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) InstallUpdates(pInstallUpdate, tType, sJobID, sActiveRequestHandle), HRESULT=87d00272 (e:\nts_sccm_release\sms\client\osdeployment\installswupdate \main.cpp,248) InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) Setting TSEnv variable SMSTSInstallUpdateJobGUID= InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) Process(pInstallUpdate, tType), HRESULT=87d00272 (e:\nts_sccm_release\sms\client \osdeployment\installswupdate\main.cpp,304) InstallSWUpdate 2012-06-13 10:15:34 228 (0x00E4) Process completed with exit code 2278556274 TSManager 2012-06-13 10:15:34 912 (0x0390) !----------------------------------------------------------------------------------- ---------! TSManager 2012-06-13 10:15:34 912 (0x0390) Failed to run the action: Install Software Updates. Component is disabled (Error: 87D00272; Source: CCM) TSManager 2012-06-13 10:15:34 912 (0x0390) MP server http://CFGMGR-SRV.zenit.brummer.se. Ports 80,443. CRL=false. TSManager 2012-06-13 10:15:34 912 (0x0390) Setting authenticator TSManager 2012-06-13 10:15:35 912 (0x0390) Set authenticator in transport TSManager 2012-06-13 10:15:35 912 (0x0390) Sending StatusMessage TSManager 2012-06-13 10:15:35 912 (0x0390) Setting message signatures. TSManager 2012-06-13 10:15:35 912 (0x0390) Setting the authenticator. TSManager 2012-06-13 10:15:35 912 (0x0390) CLibSMSMessageWinHttpTransport::Send: URL: CFGMGR-SRV.zenit.brummer.se:80 CCM_POST /ccm_system/request TSManager 2012-06-13 10:15:35 912 (0x0390) Request was succesful. TSManager 2012-06-13 10:15:35 912 (0x0390) Set a global environment variable _SMSTSLastActionRetCode=-2016411022 TSManager 2012-06-13 10:15:35 912 (0x0390) Set a global environment variable _SMSTSLastActionSucceeded=false TSManager 2012-06-13 10:15:35 912 (0x0390) Clear local default environment TSManager 2012-06-13 10:15:35 912 (0x0390) Let the parent group (Setup Operating System) decides whether to continue execution TSManager 2012-06-13 10:15:35 912 (0x0390) The execution of the group (Setup Operating System) has failed and the execution has been aborted. An action failed. Operation aborted (Error: 80004004; Source: Windows) TSManager 2012-06-13 10:15:35 912 (0x0390) Failed to run the last action: Install Software Updates. Execution of task sequence failed. Component is disabled (Error: 87D00272; Source: CCM) TSManager 2012-06-13 10:15:35 912 (0x0390) MP server http://CFGMGR-SRV.zenit.brummer.se. Ports 80,443. CRL=false. TSManager 2012-06-13 10:15:35 912 (0x0390) Setting authenticator TSManager 2012-06-13 10:15:35 912 (0x0390) Set authenticator in transport TSManager 2012-06-13 10:15:35 912 (0x0390) Sending StatusMessage TSManager 2012-06-13 10:15:35 912 (0x0390) Setting message signatures. TSManager 2012-06-13 10:15:35 912 (0x0390) Setting the authenticator. TSManager 2012-06-13 10:15:35 912 (0x0390) CLibSMSMessageWinHttpTransport::Send: URL: CFGMGR-SRV.zenit.brummer.se:80 CCM_POST /ccm_system/request TSManager 2012-06-13 10:15:35 912 (0x0390) Request was succesful. TSManager 2012-06-13 10:15:35 912 (0x0390) Launching command shell. OSDSetupHook 2012-06-13 10:15:45 1932 (0x078C) executing command: C:\WINDOWS\system32\cmd.exe /k OSDSetupHook 2012-06-13 10:15:45 1932 (0x078C) executed command: C:\WINDOWS\system32\cmd.exe /k OSDSetupHook 2012-06-13 10:15:45 1932 (0x078C) Execution::enExecutionFail != m_eExecutionResult, HRESULT=80004005 (e: \nts_sccm_release\sms\client asksequence smanager smanager.cpp,756) TSManager 2012-06-13 10:16:57 912 (0x0390) Task Sequence Engine failed! Code: enExecutionFail TSManager 2012-06-13 10:16:57 912 (0x0390) **************************************************************************** TSManager 2012-06-13 10:16:57 912 (0x0390) Task sequence execution failed with error code 80004005 TSManager 2012-06-13 10:16:57 912 (0x0390)
  2. Quick question concerning application supersedence that I can't find the answer to. If I setup supersedence on an app will that relationship only affect machines that the app has been deployed to or will machines with the superseded app see that the version they have has been superseded and upgrade automatically. I had a scenario where I setup supersedence on a version of Java and machines that were not in the collection it was deployed to started upgrading. However I had a few other things going on so I wasn't 100% that this was the cause of the random upgrade. for example "Allow clients to share content with other clients on the same subnet" was checked. But I believe that only comes into play if you have branch cache enabled and a machines has a policy telling it to request that deployment, correct? Currently I want to test deploy an app that will have a supersedence relationship but I'm worried that machines not in the test collection will see this supersedence and start upgrading. Hopefully someone can answer this for me. Typically I would test this in a lab, but I'm kind of short on time.
  3. Hi all... I'm new to the site so please forgive me if I'm posting to the wrong forum. I've recently taken a new job as a CM 2012 admin. Previously I was working with 2007 so the problem I'm having could possibly be a "feature" in 2012 that I'm not aware of. I've been converting legacy packages to the new application model and creating software metering rules. Today I thought I'd take a look at the metering report to see who things are coming along. Right away I noticed that most of the data was blank. After doing some investigating I noticed in the client software inventory that the file version column was returning the file product version instead. I suspect this has to do with some table mappings in SQL, but I'm more of a front end guy so don't have enough knowledge of SQL to investigate much deeper. I've attached a sample of what I'm seeing. Any help would be much appreciated. Thanks
