Showing results for tags 'application management'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
  • MDT, SMS, SCCM
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 5 results
  1. Patch Connect Plus, a third-party add-on for SCCM, brings two new features - Application Management, and Admin Tools to make your SCCM experience comprehensive. Application Management: 1. Select your desired application that needs to be created in SCCM from a vast repository of applications 2. Customize the application deployment with custom scripts and pre-defined application templates Admin Tools: 1. Access 25 of the most essential client management tools from SCCM console 2. Perform a wide range of functions like on-demand client operation, client troubleshooting, and system management actions You can try the fully functional version free for 30 days! Drop a comment should you have any query.
  2. Hi Everyone,
    I'm a new Level 2 Technician as i was previously Level 1 technician and my main role was helping users troubleshoot issues on their Computer and recently had a few colleagues from Level 3 started helping me get into SCCM environment were i flourishing from their Wisdom, so found your site and started to visit this site to learn a few things and decided to register.
    Thank you for visiting my page
  3. Quick question, is it necessary when updating an application with two separate deployment types to update content on each deployment type? I assume I should do both?
  4. Hello, I am wondering if it is possible to deploy an application update ONLY to clients that already have the application installed. For example Bob-PC - Java installed Tom-PC - Java installed Jim-PC - Not installed Fred-PC - Java installed Mike-PC - Not installed I'd like only the systems that have it to get it, not every system. Thanks!
  5. I am trying to figure out how to remedy a bunch of expired Microsoft updates (1,000+) that Is showing up in my SCCM console after I ran my first sync once WSUS and SUP was installed. Below are the steps take so far: Removed SUP role from my site server (SCCM) Removed WSUS from Server 2012 Restarted server Reinstalled WSUS (I noticed that the 2 previous synchronizations I performed from the WSUS console on the server was still there as if I never deleted WSUS.) Reinstalled SUP on the site server (SCCM). This time from the product list I only selected Security updates as opposed to: Security, Critical, and just plain old updates, which is why I think I have over 1,000 expired updates Also I elected to delete the expired updates as soon as they are superseded. I then let the synced the updates from the SCCM and let it run over night. I went to check the All updates section under application management node and there are about 648 new none-expired updates but the old expired updates are still there (over 1,000) I did notice also that the previous syncs that I performed on the WSUS console are still there even after I removed the WSUS role Hmmm, scratching my head.
