Showing results for tags 'sql error'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 3 results
  1. Hi, Has anyone come across this before? I am moving our SCCM database from SQL 2012 on a 2012r2 server to SQL 2019 on a 2019 server, by recovering from a backup. All seems to have gone fine, until the final step of running config manager setup again to choose the site maintenance option, to 'modify SQL server configuration', in order to point SCCM to the new server that is now hosting the database. ERROR: SQL Server error: [42000][137][Microsoft][SQL Server Native Client 11.0][SQL Server]Must declare the scalar variable "@String". : dbo.spCreateAndBackupSQLCert Create_BackupSQLCert : Failed to execute spCreateAndBackupSQLCert CSiteControlSetup::SetupCertificateForSSB : Failed to create/backup SQL SSB certificate. ERROR: Failed to set up SQL Server certificate for service broker on "SERVER NAME" . I have enabled broker, set trustworthy on and honor broker priority on, on the new instance before running setup.exe again. From some reading online, I believe it could be something to do with setting up SCCM initially with one account, but then changing it to another domain account running the service(s) and now somehow not being able to unlock the master key for the database certs. Sorry if this is making no sense, I am no SQL expert. Being right at the final stage of moving the database, I'm really stuck with this issue now, so any advice/pointers would be greatly welcomed, even if it's just to point me in the direction of which account I need to try to figure out was initially running things - I'm not clear whether that means the account running the config mgr console, the database instance, or the running the sql or sccm services. Thanks Paul
  2. Hi All, First at all, Its a pleasure to sign in to this Forum. Thanks for your support! I'm working on a secured environment and trying to install SCCM CB 1902 for a demo purpose and are stucking on an error during SCCM install on step "Generating self signed certificate on SQL Server..." My insfrastructure: - AD DC Windows Server 2016 with System Management container created and respective permissions asigned - Remote SQL Server 2016 on Windows Server 2016. SQL service account with Admin Rights SCCM computer account with local Admin Rights and sysadmin SCCM installation account with local Admin Rights and sysadmin - Windows Server 2016 for SCCM installation SCCM installation account with local Admin Rights SCCM Computer account with local Admin Rights We control User Rights Management over GPO, Services Permission, Files Permission, etc... Other services like SCOM is already working. Attached Error Msg and installation Logs. Any help? Thanks in advance Regards
  3. Hey All IT guys, I have a problem with setting up the lab enviroment - I have 2 VM's running WinSRV 2008 R2 One is DC and second is running SQL server 2008 SP3 with CU 16 - version 10.0.5852.0 I getting below error while trying to install SCCM 2012 - Also logs shows this: 9/18/2014 9:47:55 AM: ConfigMgrSetupWizard Information: 1 : Cannot detect SMS Type because either SiteServer, SqlServer or SiteServerName is empty. 9/18/2014 9:53:29 AM: ConfigMgrSetupWizard Information: 1 : Creating SQL connection to database master on server CAS.ACME.net. 9/18/2014 9:53:30 AM: ConfigMgrSetupWizard Information: 1 : Sql connection is established. Can you please advise what to do?
