sccm_freak
how to add workgroup clients to SCCM console
hello again
i have a network with clients joined to the domain and clients not joined to the domain , the clients joined to the domain are showing successfully in the SCCM console but the workgroup clients aren't , i have 2 questions here
1) how to add SCCM agent on those workgroup clients remotely , i already installed the SCCM agent manually
2) how to show those workgroup computers to be appeared on the SCCM server console
yup, you need to enable Network Discovery
read up about it before enabling though as it does add additional bandwidth load to your network
it didnt appear
i think i need to do something from the client side dont i
here are some print screens shwoing my configuration
subnets is configued in the 2nd image
domains as well
snmp is the default public
dhcp is configured as well
and the schedule to be every hour
i read an article related to the workgroup that i need to do some manual stuff on the client side related to wins ?
any help please
thanks
update :
i found those errors related to network discovery , if i can connect to the DHCP server then i can pull all the clients that are using the DHCP server and not joined to the domain , how to solve that ?
