Hi guys,
I have upgraded my sccm 2012 R2 SP1 to sccm 1511 and it seems it works. I checked the version is now 5.00.8235.1000 on the server. Now I try to upgrade my client too and I did do the following steps:
  • Going to Administration / Site Configuration / Sites
  • Click on the Hierarchy Settings button on the top ribbon
  • On the Client Upgrade tab
  • Check the Upgrade client automatically when new client updates are available
It seems that the client upgrade does not work. What can I do? Only two clients are upgraded to the version 5.00.8235.1000 but the "Software Center" is still the old version.
Any Idea why?
How can I upgrade my clients and the "Software center" to the new version?
i had this issue, seemed a little bug where even though i specified "Use New Software Center", it was still using the old software center, no matter what i did.
Turns out some people have had to manually force the new software center to be used by deleting the old shortcut and placing a new shortcut which point to the new software center .exe file (its under the ccm folder, clientux or something like that).
