Hello all
Running SCCM 1606
Hoping I can get a push in the right direction. I'm looking to uninstall a program on a few hundred PC's.  The package was deployed via SCCM , but the uninstall does not work so I dug up an PS script from online.
The following PS Script works just fine if it's ran locally on the clients.
$appVer = Get-ChildItem -Path HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall, HKLM:\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall  |
    Get-ItemProperty |
        Where-Object {$_.DisplayName -match "Some Application" } |
            Select-Object -Property DisplayName, UninstallString
ForEach ($ver in $appVer) {
    If ($ver.UninstallString) {
        $uninst = $ver.UninstallString
        & cmd /c $uninst /u
I have created a  package without any source files.
I have created a program with the following command line
powershell.exe -ExecutionPolicy ByPass -File \\servername\Applications\application\Uninstall\ps\Uninstall.ps1
Runs with Administrative rights
Runs with UNC name
Whether or not a users is logged on.
I deploy to the collection that has this piece of software installed but it never runs on them. I have allowed PowerShell execution on the client settings. I can push other SW to these computers by they way.
Any help would be very much appreciated.
Edited by Dubs_sccm
left out some info
First what didn't work when you created the package the first time?
Secondly, your problem is you are trying to run a PowerShell script from a UNC path. The Computer account will NOT have access to that path. Therefore it will fail. Why don't you include the posh script within the package source?
The Package source folder is a UNC path that contains the posh script.
pss3.png.06cea5f310c50a8ec090e18eafd526f4.pngThanks for the reply.
Then the program is the actual posh script. I have tried browsing the the scrips locally , when i deploy I don't get any computers getting this PS script.
This program also uninstalls by a simple uninstall.exe /u/ Hell it even uninstalls by creating a batch file and running it from a share on sccm server, but it's getting that batch or powershell to to clients os the biggest pain i am facing. So any advise to how I can get rid of this program would be wonderful.
Dont really care how brutal the method is as long as sccm can do it.
9 kb · Done
I then have a program
Edited by Dubs_sccm
Go back to Basic.
Did you deploy the package to your DP?
Does the Package show up within the CM cache folder?
Does the program run as Local system account?
