Build and Capture
Guys
I am trying to run a 'Build and Capture' on Windows 10 1709..
All works fine until the Capture Operating System [obviously last in the list] section of the Task Sequence..
when this runs the target machine [tried physical and a VM with same issue] has lost its NIC driver, so it connot write the WIM to the network share
Has anybody seen this before?
OS's...
Target build is Windows 10 1709 Enterprise
SCCM is 1710 on Windows Server 2012R2
using the Command Support [F8] dos window and IPCONFIG command I can see the NIC seems to be lost as the Sysprep command is ran, then after reboot does not find NIC even though drivers work fin in BOOT WIM on the initial boot at the start of the TS
