Scripteur
Problem deploy OS on computer that has 2 or more disks
I need your precious help.
I tried to deploy W10 OS using captured image and task sequence on computer that has 2 disks.
there is W7 OS already installed on disk 1, I have created a package included a powershell script that detect automatically the disk index where the W7 OS already installed and change value of OSDDiskindex variable accordingly so in next step Format and partition TS take this variable into consideration, but no success!!
My aim is to deploy W10 OS on this same disk but I am not able to use OSDDiskindex effeciently in my TS.
Could you a please help me? Your help will be so much apprecied!
the first thing i'd say is why 2 disks ?
and, when you say it's not working efficiently, can you explain what is not working exactly ? what errors are you seeing, and can you zip up and  attach the smsts.log ?
Thanks for your quick reply.
In our company, there is some developpers that need two disk on their computers.
here is the command line that I execute before Format and partition step.
powershell  –executionpolicy bypass "@{
Get-WmiObject Win32_DiskDrive | % {
  $disk = $_
  $partitions = "ASSOCIATORS OF " +
                "{Win32_DiskDrive.DeviceID='$($disk.DeviceID)'} " +
                "WHERE AssocClass = Win32_DiskDriveToDiskPartition"
  Get-WmiObject -Query $partitions | % {
    $partition = $_
    $drives = "ASSOCIATORS OF " +
              "{Win32_DiskPartition.DeviceID='$($partition.DeviceID)'} " +
              "WHERE AssocClass = Win32_LogicalDiskToPartition"
    Get-WmiObject -Query $drives |Where-Object {$_.DeviceID -eq "C:"} | % {
      $MonDisk = New-Object -Type PSCustomObject  @{
        Disk       = $disk.index
      $MonDisk.Disk
(New-Object -COMObject Microsoft.SMS.TSEnvironment).Value('OSDDiskIndex') = $MonDisk.Disk }"
and error is :
Le moteur d'exécution des séquences de tâches a terminé l'action (Set Disk number) dans le groupe (Installer le système d'exploitation) avec code de sortie 0
Sortie de l'action : ...  = $disk.index       }       $MonDisk.Disk     }   } }  (New-Object -COMObject Microsoft.SMS.TSEnvironment).Value('OSDDiskIndex') = $MonDisk.Disk }" returned 0
Au caractŠre Ligne:1 : 7
+ @{ Get-WmiObject Win32_DiskDrive | % {   $disk = $_   $partitions =
ASSOCIATORS  ...
Op‚rateur ®ÿ=ÿ¯ manquant aprŠs la cl‚ dans le litt‚ral de hachage.
ASSOCIATORS  ...
Le litt‚ral de hest incomplet.
Au caractŠre Ligne:1 : 648
+ ... k     }   } }  (New-Object -COMObject
Microsoft.SMS.TSEnvironment).Value('OSDDis ...
Jeton inattendu ®ÿ(ÿ¯ dans l'expression ou l'instruction.
Au caractŠre Ligne:1 : 738
+ ...$MonDisk.Disk }
Jeton inattendu ®ÿ}ÿ¯ dans l'expression ou l'instruction.
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordEx
   ception
    + FullyQualifiedErrorId : MissingEqualsInHashLiteral.
thank you for your help!
so you are running an English PowerShell script on a French OS ? that might be part of your problem, "ASSOCIATORS OF" might be something else in French..just a thought
have you actually tried running this script on that computer without running it in the task sequence,
  will fail as no task sequence is running but if your script works (and i'm not sure it is working), then you should get some valid output
Thanks for your reply!
no problem with the script, it is given me the right Output, my problem is how to set this output ( OSDDiskIndex variable) in my Task Sequence.
but you pasted above that it's producing an error on line 7 ?
I can't see that you can use it if it produces errors when run during the task sequence, how can it set the variable if it doesn't work, do you see my point ? if I was using a script to set a variable i'd add a logging function to see where it's failing, below is an example function
Function LogWrite
   Param ([string]$logstring)
   $a = Get-Date
   $logstring = $a,$logstring
   Try
    Add-content $Logfile -value $logstring  -ErrorAction silentlycontinue
Catch
    $logstring="Invalid data encountered"
   write-host $logstring
# script starts here
$Logfile = "C:\Windows\temp\logfile.log"
so for each action in your script use
LogWrite "about to do... whatever"
so you can see where it fails...
once you fix the script, then you can use the variable in the task sequence
I can confirm you that this script is working when execute in localy in my machine, you can test it in your machine to be sure. thanks
  $disk = $_
    $partition = $_
        Disk       = $disk.index
      $MonDisk.Disk
yup works ok for me, so before we go any further, can you explain where you got the error's you posted, and what happens when you run the code pasted directly above this reply on that machine (and not in the task sequence), does it produce an error, or not,
or, do you only see an error when you run the script via the task sequence
Exact I see the error when I try to apply the output to OSDDiskIndex variable in the task sequence using Run Command Line :
thanks
doesn't look like it's an error, have you tried to dump the variables created to verify it it set's the variable at all ? i'd suggest you pause the task sequence before and after the step to verify
Hello, I would like to ask how to install the system on multiple hard disks. There are script files to share. When there are multiple hard disks in my computer, the deployment system should be installed on the disk number partition where the original system is specified. Is there any solution?
你好,请问 在多个硬盘上 安装系统 可有脚本文件分享啊,  当我电脑存在多个硬盘时候,     部署系统要安装在原来系统指定所在的磁盘编号分区上,有什么办法解决吗
you'll need to create a custom script to detect where that original system is installed, and use that for the apply operating system step (using a variable), but read my first comment in this thread....
On 2018/8/30 at AM3点00分, anyweb said:
您需要创建一个自定义脚本来检测原始系统的安装位置,并将其用于应用操作系统步骤(使用变量),但请阅读此线程中的第一条注释....
你好,请问该如何编写脚本应用, 无奈对脚本不熟悉,是否有空请帮忙写个检测系统目录脚本吗?
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
