Hi Niall,
I am facing issue while upgrading 1802 from 1706. It is not moving forward from update content library stage. I tried all possible troubleshooting. SQL rights are correct, I tried removing the GUID and downloaded again. I already removed update using CMUpdateReset.exe multiple times, Under CMUpdate.log its showing "There are no pending update package to be processed". please help
CMUpdate (2).txt
Edited by amit paul
cmupdate file attached.
from the log there are several reports of SQL access issues, double check your permissions before trying again.
*** [42000][4060][Microsoft]
[SQL Server]Cannot open database "CM_MDC" requested by the login. The login failed.
