Hi Niall
Thanks for the great video tutorials and past SCCM guides.
This is my first experience of MBAM and I've managed to follow your guides to deploy MBAM polices and portals in SCCM 1910 and MECM 2002. I now want to move on to including MBAM in the OSD task sequence. There are a few posts on various forums with conflicting information but no complete guide and mostly written for standalone MBAM or Windows 7.
If you have time please create a new step\video to show how it's done by the professionals :)
On 5/6/2020 at 1:46 PM, anyweb said:
yes its possible, if you are using SCCM 1910 follow my video
if you are using MEM 2002 then set the corresponding settings in the wizard to have no delay
Hi Niall,
Thank you, I deployed it to 10 test units over the VPN.
Only 1 so far worked as intended.
Few Question.
- I can see in my BitlockerMangaement GroupPolicyHandler that its trying to enforce keys into registry. But I am not seeing them other then those 2 custom one enforce using baselines. Is there way for it get force more frequently?
Screen Shot
I will be updating SCCM to 2002 soon too.
that's the MDOPBitLockerManagent key, what's the parent FVE key? also is your configmgr client agent the correct version ? is the computer in a collection targeted with the bitlocker management policy ?
May be is this what you mean? : http://prntscr.com/sjx7f3
17 hours ago, anyweb said:
ok you don't understand what i'm saying, do you have teamviewer so i can take a look ?
Yes I do.
